Help me out guys its doing my nut in
  • jaydagreek
    • Sep 2009
    • 13
    right here goes i ve soft modded wii s in the past succsesfully but cant get it right on this 1 for my mate its serial number is leh 177 the hombrew channel has installed as well as the back up channel.the problem is i cant get the backups to work i ve only go the 1 im using ta test as i dont have any others the 2 disk s im burning onto are verbaitim s - or signalix - not having any luck been doing this for thae last 4 weeks and im losing it oh yeah its running on 4.0 please please please help thanks guy s i appreciate it
  • jaydagreek
    • Sep 2009
    • 13
    1 last thing i ve got it set to iso 35 ?? is that right ?
    • stavross
      • 44
      Hi M8
      Try installing ****i****s ios38 rev 14 or the updater.
      Hope this helps M8
      Stavross
      • dell_xps
        • 2558
        Update it to 4.2, then use the easy to follow tut m8.
        Be done in no time.
        • jaydagreek
          • Sep 2009
          • 13
          is it safe to update with the homebrew and backup channels on or should i uninstall first ??? cheers for the help m8
          • dell_xps
            • 2558
            Once updated you will have to put the homebrew channel back on, all steps are in the tut m8.
            Takes about 30 mins from start to finish.
            Update the Wii via the Nintendo server using your wifi.
            HTH
            • jaydagreek
              • Sep 2009
              • 13
              cool dude but is it ok to update while everything is still installed ? or do i have to manually uninstall everything before update? sorry dude my heads well been spinning wi this like
              • dell_xps
                • 2558
                It's ok to update with everything on m8, rememebr you have to install from scratch again, takes 30 mins tops to install homebrew channel then softmod ok.
                • jaydagreek
                  • Sep 2009
                  • 13
                  cheers m8 ill give it a shot and leave the feedback thanks again for the help and have a great new year :P
