thanks mate i was going to wad manager pressing A then scrolling left and right to change to ios58 but it wasnt there
what your saying is at that point i have to select ios249
done as you said installed the ios58 rebooted it still says an error has occured on the usb camera turn off console
has the camera got a microphone on it ?as this can cause a problem,i know the camera off xbox 360 live works
not that i now of what i do no is that i have 2 cameras both logitech one of them is of the old playstation 2 which is a great camera not sure wether i was doing something wrong
after all that hard work nothin,at least youve learnt how to use wad manager along the way,perhaps you can borrow a cam from somebody else thats not a logitec,must of dropped lucky with mine,let us know if you have any look.
cheers
I BOUGHT THIS GAME AND IT WANTS TO DO A SYSTEM UPDATE BUT WILL THIS THEN DELETE MY HOMEBREW CHANNEL IF I UPDATE THROUGH DISC
SO I HAVE DOWNLOADED THE GAME AND INSTALLED ON THE HD BUT I AM GETTING THE USB CAMERA ERROR
SO IF I INSTAL THE IOS58 WILL I BE ABLE TO LOAD OFF USB HD OR WOULD I HAVE TO PUT ONTO DISC AND LOAD THROUGH BACKUP L;AUNCHER
HOPE I CAN GET IT WORKING THROUGH USBHD CAUSE DONT WANT TO KEEP UNPLUGGING THE THING TO RUN YOUR SHAPE
if your on 4.2 you can accept the update as your on the latest system and it will be the camera driver,if your not install the ios58 that will get you up and running from dvd-r loader and usb,ive read somewere that you can use a usb port splitter ,so you can run usb and cam.hope this helps
YES M8 IM ON 4.2E SO IF I UPDATE USING THE ORIGINAL DISC IT WONT DELETE ALL THE SOFTMOD THEN
ALSO CAN I NOT USE THE OTHER USB PORT PORT THEN OR DOES IT HAVE TO BE THE PORT THAT THE HD USES
