ok first thanks in advance for ne help. I have softed modded my wii going back the beginning of 2009 all was fine til some 1 messed around with it no i think i have figerd it out just dont no how to fix. right then the normal wii game loader thinks it is usa but the machine is pal the homebrew channel just restarts the machine and its got the wii options semi brick i have tried to reistall homebrew through other softmods but still does not work please if ne1 can help that would be great
please can ne1 help
M8 from what I can make out of your 1 long sentence, it sounds as if you have loaded a NTSC title and upgraded the firmware from that onto your Wii.
You will have to either update your Wii to a later version of firmware that is on your Wii or have an expensive paper weight.
Use an original PAL Wii game, quite new to update to a newer firmware, or update to the very latest 4.2E via the Wii using your wifi.
HTH
sorry about the long sentence i do that somtimes, ive tried to go in to options but get that opera thing and the thing cant read a pal disk to update, so i think it might be proper broke thanks for the advice ne way cheers mate
