wii brick blocker
  • Tarletonjon
    wii brick blocker
    Can anyone help me. I hav chiped WII and have had no problems in downloading games untill now. I have just copied New SuperMario ros and Rock Band The Beatles. On both of these games when I try to play them the WII hants to do an update before I can play. If I do the update wll it block my WII....Do I need a brick blocker?
  • ck-ok
    • 2592
    yeah Digital Kaos - Downloads - brickblocker dont update system this will block any updates.
    • renke_uk
      • 53
      Do you have BootMii as Boot2 and a Nand Backup or Priiloader Installed?
      Priiloader can be set to Block online & disc updates automatically.
      Regards
      SoftMod Essentials:- Dop-Mii V12 --- CFG USB Loader FAT32 --- Wii Game Manager
      • batman44
        • Mar 2009
        • 276
        Try this if you downloaded a game, do this first before burning or playing, it will also take out the region code if it ntsc.
        Keep calm carry on.
        • sleek1
          • Oct 2010
          hi great lilttle tool, helped me out with my region problem
          • gwilson2010
            • Dec 2010
            Does anyone know of any games this won't work on?
            • ck-ok
              • 2592
              please make your first post in the introduction section.
              works on all iso's
              • qball1234
                • Nov 2011
                cheers mate
                • sarahsamuel
                  • Apr 2011
                  wii 4.3e
                  please can someone help. i have a wii that was updated to 4.3e and want to have it hacked so that i can play copied games. does anyone have an answer????????
                  • hawk1977
                    • Nov 2011
                    is the wii4.3 e the same as the u
                    what is dif in the the wii the new wii i got was wii 4.3u not e
                    • happy_highlander
                      • 3535
                      U is for usa e is for europe meaning u will play ntsc games and e will play pal
                      • Keithuk
                        • 2264
                        You will need a 2GB FAT32 formatted SD card to load the downloaded files on to.
                        Well if your running 4.3 then you can use LetterBomb to softmod ONLY your Wii. The first job to do as you are installing HBC and BootMi is prepare SD card so you can run BootMii and backup your NAND. Then you need to install PriiLoader 0.7 to block any updates and do other tweaks which can be found on here. Then you need to follow the tutorials on adding USB Loaders on here.
                        You will also need a suitable external hard drive to hold these games.
                        As HH says
                        E - Europe and Australia
                        U - USA
                        J - Japan
                        K - Korean
                        Just because its an 'E' doesn't mean you can only play PAL games NTFS games play as well. This should be the same if your is 'U'.
                        Keith
                        2010 Golf GTD (170)
