Burning games!
  • delboy71
    • 122
    Burning games!
    hi all, i have burned about 3 or 4 discs now and they load up in the wii, opens the intro to games but then i keep getting the error: the disc could not be read,please refer to user manual.
    anybody have an idea what might be causing this?
    im using imgburn at the discs lowest speed, the discs im using in imgburn show as TYG02 so i assume they are Taiyo Yugen.
    cheers
    Delboy71
  • ck-ok
    • 2592
    use verbatin dvd-r slowest speed
    • smoggie
      • 863
      I usally use ritek go5, burn at x4 with either nero or img burn and i usaully have no problems
      • cablegt
        • 19
        I'm using maxwell dvd-r with img burn,The first speed i tried was with a x4 speed and they kept failing, so i started to burn at x1 speed they all burnt ok.
        • mav388
          Hiya guys I am new here so I'll try and tell you the way I burn games(about eight so far).
          I have two programmes to do this : ISOBUSTER and IMGBURN.
          I load the iso into IsoBuster then right click and press find missing files and folders (this takes a few minutes).
          Then I use ImgBurn to burn the iso to disc at whatever speed it decides usually 6x or 8x.
          This has not failed me yet and I use RITEK F16 dvd+r .
          Hope this helps.
          • amjad3000
            • 14
            cheers
            Delboy71
            You can use any dvd i use dvd+r but keep the speed as minimum as possible e.g 2x this will allow your console to read it properly, hope this helps.
            enjoy.
            • amjad3000
              • 14
              Burn games
              yeah u need to put ur writing speed lower this hsould do the trick.
              • ck-ok
                • 2592
                hi all dvd-r or dvd+r they can both work but i only buy dvd-r because of the easy compatibilty,its all down to book typing.
                DVD-R can not be booktyped. So the booktype settings do not apply to DVD-R media.
                DVD+R should be booktyped to DVD-ROM for better compatibility.
                Some burners automatically booktype DVD+R media to DVD-ROM. In this case you do not have to manually set the booktype since it is automatically done for you. Some burners do not booktype DVD+R by default so you will need to manually booktype the DVD+R media to DVD-ROM.
                So find out if your burner auto-booktypes or if you manually have to booktype DVD+R media.
                Depending on the burning software will depend on how you booktype. If you are using IMGBurn then the booktyping option is the little open book icon at the bottom right hand corner of IMGBurn. Use this option to booktype DVD+R media to DVD-ROM if you manually have to booktype your media.
                • smoggie
                  • 863
                  can somone advise me on this, but will the spec of the pc determine on fast you can burn a disc without getting a problem?? Reason I ask is when i upgraded pc a couple of years ago to 4gb ram, intel e6600 processor & new mobo when i convert xvid to dvd its so much quicker
                  • ck-ok
                    • 2592
                    copying to cd or dvd is determind by the discs you use ie x16 will be the fastest you can burn
                    • cgscott
                      • 3513
                      The reason you can convert quicker is because this uses the cpu and memory.
                      But when burning or ripping disks this is determined by the speed of the dvd drive or max speed of the disk.
                      Patience is a virtue.
                      • delboy71
                        • 122
                        I have now used verbitim discs and in uloader i get error dvd -2 grrr
                        • ck-ok
                          • 2592
                          what system number are you on? when did you buy your wii?and what game are you trying to play?also what burning software are you using?
                          • delboy71
                            • 122
                            using 4.2e, wii is about 18 months old. got mario kart working fine.. it maybe just some duff games im downloading.
                            call of duty modern warfare was loading with my older discs but then crashed,but now im using verbitim but they wont let me write at real slow speeds the minimum they will burn according to imgburn is 6x.
                            • ck-ok
                              • 2592
                              you might have some duff games,give this a try http://www.digital-kaos.co.uk/forums...ma8-r17-84545/ and let us know,x6 is ok,its same as mine.
