I don?t take any credit for this information, this is just a "Copy and Paste" from different post around the net.
All the credit should go to the original posters.
1. Download Trucha Signer 0.21 http://www.ingenieria-inversa.cl/files/trucha021.rar
2. Download RegionFrii 1.21 http://gbatemp.net/index.php?download=722
3. Download Ultraedit http://www.ultraedit.com/
4. Unzip everything and put them into a central directory.
5. Open up the "wiikeyset.reg" that came with the Trucha Signer in UltraEdit and find the section:
[HKEY_CURRENT_USER\Software\Wii\KeySet\2]
"name"="Custom KeySet 1"
"boot1 key"=hex:00,00,00,00,00,00,00,00,00,00,00,00,00,00 ,00,00
"common key"=hex:00,00,00,00,00,00,00,00,00,00,00,00,00,00 ,00,00
"sd key"=hex:00,00,00,00,00,00,00,00,00,00,00,00,00,00 ,00,00
"sd iv"=hex:00,00,00,00,00,00,00,00,00,00,00,00,00,00, 00,00
"md5 blanker"=hex:00,00,00,00,00,00,00,00,00,00,00,00,0 0,00,00,00
6. Open the key.bin file in UltraEdit and make sure you are in hex mode (Ctrl-H).
* key.bin (You need to find it and download it for yourself, can?t link to this file)
Google it! It will have an MD5 of 8D1A2EBCD82A3469B77FACF15D9C8E50
7. Replace the "common key" line...
...with the contents from key.bin. For example, if key.bin contained AABBCCDDEEFFAABBCCDDEEFF11223344, you'd enter...
"common key"=hex:AA,BB,CC,DD,EE,FF,AA,BB,CC,DD,EE,FF,11,22 ,33,44
8. Save the "wiikeyset.reg" file and activate it by double clicking on it. Click "Yes" to add it to the registry.
9. Start Trucha Signer and Select KeySet->Custom KeySet 1
10. Click Image->Open ISO and load SSBB ISO
11. Expand DISC->PARITION (RELSAB)->ROOT
12. Right click __update.inf and select extract to file (save it to your desktop and then delete the file)
13. Download Prophets modified __update.inf http://www.filefactory.com/file/6672f5
14. Right click __update.inf in Trucha and select Replace and browse for Prophets ProphSSBB.inf
15. Right click PARTITION (RELSAB) and select Trucha Sign It! (do the same to PARTITION (RSBE01) just to be sure)
16. Close Trucha and start Regionfrii.
17. Load the SSBB Iso and select New Region->PAL (Default) and click Update ISO
18. Download and install ImgBurn http://www.imgburn.com/index.php?act=download
19. Start up ImgBurn and go to Tools->Settings...->Write->Layer Break->User Specified and enter 2084960
20. Burn the game to a DVD+R DL
21. Insert the game to your Wii and if it asks to update let it update 100%
22. Enjoy Brawl on your PAL Wii without dual channels
Thank you all that posted all this information and I hope you don?t mind that I collected it all in one post.
Hope this will help a lot of confused ppl
EDIT: Forgot to mention my setup: PAL Wii 3.2E with D2CKEY (But it should work on all modchips)
I did not need to do this part myself
Additional info for some users:
Remove the 001 Error:
Do this between step 14 and 15.
1. Go into the second partition PARTITION (RSBE01), extract the main.dol
2. Load the main.dol with the bailli tool and hit " remove 001. then hit SAVE. if you do not hit save, it wont fix it.
3. In trucha signer, right click the main.dol that you just extracted and hit replace
4. Right click the partition in trucha signer and resign the partition
Change the Video Mode to support 480p/480i/576i
If you are patching for "Remove the 001 Error" do this after step 2 on the same main.dol file that you have already patched with baillis tool.
2. Load the main.dol with the Wii Video Mode Changer 2.2 http://rapidshare.com/files/98050614/wii-vmc_2.2.zip
3. Select Smart Mode, NTSC->PAL
4. In trucha signer, right click the main.dol that you just extracted and hit replace
5. Right click the partition in trucha signer and resign the partition
