Error with USB Loader but fine with ULoader
  • sidneysides
    • Feb 2010
    Just modded 4.2E fine with this tutorial on here.
    Works fine with the 2 games I've tried so far with ULoader version 4.1
    Tried same games with USB Loader 1.5 but get 002 error with both of them. I prefer the look of the interface of USB Loader so would like to use this one. Any ideas why I get this error? I must have the correct WAD files for the games as they work fine with ULoader.
  • stopmotion
    • 26
    A lot would have said Your ISO is damaged etc ... It's not at all ...
    Like You say ... It works on One but not the Other ... And even If
    You go to options on USB Loader and Turn 002 fix on ... You usually get the Same problem,
    My Strange One is that USB Loader Worked Fine for Me until I added
    The Covers ... Then nothing would load ... So I was Forced
    to use ULoader which is Pretty good but even that won't Load a
    ISO that I know Works ... I put it down to just Bugs etc ... I think
    we all have individual Wii's and some do and some don't ...
    With ULoader I'm also pulling the Plug out the Back a Lot because
    I just get the Black Screen and reset etc are locked,
    One thing to Do is make sure You have the Up to Date
    ULoader and keep messing with the Settings ... I've tried a
    Few In Both ... Press "Home" for ULoader and same I think
    for USB Loader ... USB Loader has more settings and some
    I can't figure out ... Sorry I could'nt Help and Good Luck
    • ck-ok
      • 2592
      have you tried going into menu and updating usb loader via wifi cause the newer versions have the 002 fix?or if you have a newer version have you switched the 002 fix on and saved it in the settings?
      • paulwoody
        • 5
        Forget about the way the interface looks and carry on using Uloader.Uloader and USB Loader are just a means to an end.It's all about the games working.
        • kimi199
          • Nov 2010
          is the cisox rev20 update for ciso rev10?
