homebrew channel+hack
  • roberttaylor40
    • 100
    i have loaded homebrew channel,when i was loadig ios wads some were coming up with error/then when i trid to install clocorp v3.3 installer,it says install cios rev07,before installing,my wii is 3.4 version,can anybody help.
  • ck-ok
    • 2592
    whos tut was you following?have you got preloader installed or have you got bootmii as boot2,cioscorp is a great way of bricking your wii be careful
    • roberttaylor40
      • 100
      hi preloader wont install,either,i am not putting bootmi on as i might brick it,do you have a link so i can put hach and homebrew on my wii,many thanks.
      • ck-ok
        • 2592
        follow this tuturial http://www.digital-kaos.co.uk/forums...eupload-56964/ and you cant install preloader on a 3.4 wii,good luck
        • roberttaylor40
          • 100
          i followed guide,every thing fine,but when i put normal game in now its coming up with a wii update,will it be ok to do wii update,i tried to load wii fit plus when it came up with wii update required to play game,how can i get all games to work.
          • ck-ok
            • 2592
            i followed guide,every thing fine,but when i put normal game in now its coming up with a wii update,will it be ok to do wii update,thanks.
            no dont let it update
            • ck-ok
              • 2592
              if you dont wont to worry about updates then use this Digital Kaos - Downloads - v4.2 safe firmware updater this will get you to 4.2,the highest update on a game is 4.1,so you wont have to worry about updates,if a disc does ask to update then it will just want to update some isos nothing to worry about
              • roberttaylor40
                • 100
                i did not do 4.2 update as some games work,but wii fit plus,sports resort,dont work,if i update to 4.2 will this solve problem,i am worried about doing up date as im not sure what to do,many thanks for all help.
                • ck-ok
                  • 2592
                  running 4.2 updater is easy just put it in apps folder and run it from homebrew and follow on screen messages,it wont let you play anymore games but you will be able to play the games that wont to update,as for playing wii sports resort you need to use a alternative .dol read this Wii Sports Resort with a wii with 4.1? - GBAtemp.net and pick the one for you
