cIOS36_rev9-installer problems please help
  • m9g
    • 704
    when running the custom IOS installer 1.6, i choose "netwrk installation"
    It downloads IOS 1-14 patches fine
    it adds 15 ok
    Then when it installs the custom IOS i get an error....
    "installing ticket.... ERROR! (ret = -2011)"
    Any ideas whats wrong please and how i can sort it.
    Many thanks
    M9G
    DONT FORGET TO CLICK THE THANKS BUTTON IN THE BOTTOM LEFT CORNER OF THE POST IF ANYONE HELPED YOU
  • m9g
    • 704
    just tried version 10 aswell and get the same problem
    HELP!!!!!!!!!!!!!!
    • m9g
      • 704
      and version 15 still same
      what is wrong?
      • ck-ok
        • 2592
        what is wrong?
        try this when you installed everthing you should be able to install cios36
        • m9g
          • 704
          thanks but....
          i put wad mangaer into apps file
          put the 2 wad files into a wad folder on the root of the sd card
          ran wad manager and directed to the wad folder
          tried installing both wad's and get the same ticket error
          what is this blummin ticket thing?
          I keep reading about bootmii - di i have to have this installed as i havn't
          M9G
          • ck-ok
            • 2592
            thanks but....
            M9G
            did you use your standard wad manager to
            install IOS16-64-v257-prod.wad first and then start the special wad manager to load fix wad? what is wrong seems to be that trucha signing is disabled you may of missed a step in your initial set up
            • m9g
              • 704
              I used wad manager 1.4
              • ck-ok
                • 2592
                try using wad manager 1.3 google it,then start it up and try and install ios16-64-v257 even if you normaly get errors this should load,if t does then start the other special wad manager for ios16 and install fix wad
                • m9g
                  • 704
                  Tried 1.3 and same as 1.4 on installing ios16-64-v257 i get error....
                  "installing title..... ERROR! (ret = -1035)"
                  gggrrrrrrrrr
                  • m9g
                    • 704
                    phew!!!!!!! sorted it
                    Nightmare!!!
                    In the end i followed this...
                    HOWTO: Setup a System Menu 4.2 Wii for playing backups of commercial games with uLoader Ade's Softmodding Wii blog
                    Worked perfectly, got a backup of my new mario to load from HD
                    Thanks for your help
                    M9G
