movies on wii
  • atlis
    • Feb 2010
    • 45
    movies on wii
    just soft modded wii! i read that you can play movie files via usb what do i need for this? any help?
  • ck-ok
    • 2592
    Digital Kaos - Downloads - MPlayer CE cIOS Installer
    Digital Kaos - Downloads - mplayer ce 0.75
    Digital Kaos - Downloads - MPlayer CE Forwarder channel
    install these
    • atlis
      • Feb 2010
      • 45
      thanks v much i assume when u say install these you mean drag them onto sd card and open homebrew
      • ck-ok
        • 2592
        yeah first two in apps folder last one in wad folder and install with wad manager
        • atlis
          • Feb 2010
          • 45
          1 more thing do i need to foermat my usb drive to wbfs?
          • ck-ok
            • 2592
            as far as i can remember yes
            • atlis
              • Feb 2010
              • 45
              Having trouble trying to format, its an 8gb usb stick. im using vista and wbfs wont recognise my stick
              • cablegt
                • 19
                No you dont use wbfs,just format it to fat32 or ntfs.Copy over film to usb stick and open mplayer..WBFS is just for games...
                • atlis
                  • Feb 2010
                  • 45
                  thank you dude!
                  • ck-ok
                    • 2592
                    thanx for the help cablegt,its been a long time since ive played a movie off usb stick,normally stream them from pc.
                    • cablegt
                      • 19
                      Thanks guys just hoped i help you out..
                      • delboy71
                        • 122
                        ck-ok how do you go about streaming movies on your wii?
                        • ck-ok
                          • 2592
                          try this
                          SMB shares.
                          First make sure the folder on your PC is shared with the network. It will assign it a default name which you might want to change.
                          Then..
                          In the Mplayer CE folder on the SD card there'll be a smb.conf file.
                          #Max 5 samba shares (review menu.conf to add more samba browsing)
                          #no ip or no share means samba disabled
                          #It's important use quotes (") on shares with blank spaces, see example 2
                          #Samba share1 (smb1:/)
                          ip1=192.168.0.1
                          share1=films
                          user1=
                          pass1=
                          #Samba share2 (smb2:/)
                          ip2=192.168.0.1
                          share2="My movies"
                          user2=
                          pass2=Then it's just a matter of editing the details to match your PC configuration.
                          Enter your PC Local IP, it'll not likely be 192.168.0.1 but something similar.
                          Enter your Share Name, noting that separated words must be enclosed with quotes.
                          Once you reinsert the SD card and launch Mplayer CE it will allow you to connect to the shares.
                          • bugaloo41
                            • 1598
                            Cheers CK.
                            Updated my Wii a couple of weeks back to usb loader (which is superb) and forgot ho to set up CE player. Works a treat.
                            • m9g
                              • 704
                              OOOooooo how do you stream from the pc
                              DONT FORGET TO CLICK THE THANKS BUTTON IN THE BOTTOM LEFT CORNER OF THE POST IF ANYONE HELPED YOU
