Using cheats with uloader
  • sam.walker22
    • Feb 2010
    • 11
    I am unsure as how to use cheats with uloader
    From what I understand, you make a 'codes' folder in the root of your sd card and put the cheat files in there and uloader will detect them when you press load game.
    I'm getting my codes from this site: GeckoCodes.org
    Do I need to download the .txt files or .gct files?
    If its the .txt files I need to use, if I want to play Mario Kart with cheats, would I just download THIS file and put it in the 'codes' folder or do I need to change anything?
  • stopmotion
    • 26
    Not Heard of that way to be Honest But I did Try Myself and
    succeeded this way ...
    I downloaded "Cheat Manager V0.3" so It was in the Homebrew
    Channel ... Then I made a Directory on My SD Card called
    "txtcodes" < Without quotes ... I've a feeling it makes this
    Folder but I made it just in case ... I then Placed SMNP01.txt in that txtcode Folder ...
    The Text is the Cheat for New Mario Bros,
    Then I downloaded Gecko OS 1.9.3.1 so that was ready in the Homebrew
    Channel ... I already had New Mario Brothers in the Dvd Drive so
    this is where I have'nt tried further ...
    I booted Cheat Manager up ... Selected The SMNP01.txt and
    Pressed "A" ... It then Listed allsorts of Cheats for the Mario
    Game ... Using the D-Pad I went down and added a "+" to
    some Boxes for the Cheat to be activated ( Use - and + to activate
    and deactivate ... Once done I Pressed "1" to generate ... It will
    Quickly show some Txt and tell You to Press any Key ... Press
    Any key and press "Home" ... Then While still On the Homebrew
    Channel ... Start Gecko ... Press "A" on Launch Game and it worked ...
    So I'm only sure how to do Games on Dvd ... Have'nt
    Tried USB ... Hope This Helps
