guitar hero 5
  • ck-ok
    • 2592
    guitar hero 5
    Guitar Hero 5 - Run from Disk Guide:
    1. Install this wad.
    IOS56-64-v5146.wad
    2. Download and run multi cios installer, and install IOS 37 as IOS 223.
    3. install softchip with wad manager
    4. run SoftChip, make sure to use IOS 223 and make sure the 002 Fix is enabled.
    insert backup and away you go
  • skitzlad101
    • Mar 2010
    This ios is also needed to play the new rugby league 3
    • pomster
      • Mar 2009
      • 119
      IOS56-64-v5146.wad
      2. Download and run hermes cios installer, and install IOS 37 as IOS 232. and ios 222 as default.
      3. run SoftChip, make sure to use IOS 232 and make sure the 002 Fix is enabled.
      Hi people i have followed these instructions but i am still stuck, can someone pls help?
      when i try to install ios 37 as 232 or 222 i get the following msg,
      downloading metadata from internet
      initalizing network done
      net connect failed -26
      error making http request
      failed to allocate temp buffer for encrypted content
      size was 2148483232,
      And thats it i cannot do any more, when i go into the softchip channel there is no 232,
      very gratefull if anyone can help!
      • ck-ok
        • 2592
        could be your internet is not set up right or the server is down try another day and see if you have more luck
        • pomster
          • Mar 2009
          • 119
          Cheers for the reply, server is not down an i have been trying this for a long time now! mad thing is i can download any updates except this, also when i first modded my wii i could play on line but it only lasted a week then went off,
          if i check connection settings through my wii it says theres no prob
          any ideas?
          • ck-ok
            • 2592
            try installing the wad version then install softchip with wad manager ,ive updated the first post
            • rLLZORS
              thanks for the post
              • osquilla
                ya tengo ganas de jugar al juego, sorry my english no good ?
                • matrix71
                  • Mar 2010
                  thanks for this
                  • maodayor
                    Thanks a lot dude been looking for this.
                    • happy_highlander
                      • Aug 2010
                      • 3535
                      I'm getting black screen when I try to load from wii flow I've tried every option I can find with same result is there anything I need to install. I've now tried wad and soft chip install but cannot get this game to run from hdd or disk, any help would be much appreciated.
                      • ck-ok
                        • 2592
                        have you tried using a different loader like soft chip or configurable usb loader?
                        • happy_highlander
                          • Aug 2010
                          • 3535
                          I have now and have edited the post and by the way I have tried pal and ntsc versions with same result. Am I correct in thinking metroid other m needs the same ios cause i don't have any problems running that with wii flow
                          • ck-ok
                            • 2592
                            did you use multi cios installer, and install IOS 37 as IOS 223.then starting game with 223
                            • happy_highlander
                              • Aug 2010
                              • 3535
                              I tried that way before installing wad option but when I try to install 38 and 37 merged (the only option it gave me) into 223 I just get a code dump. I'm going to try extracting files with 7zip instead of winrar and give it another go I think I will keep you posted. I have now tried after unzipping with 7zip same result with ios installer whenever i try to install 38 and 37 merged or in fact whenever I try to do anything with it I get a code dump. After installing 223 as wad option when I load softchip select ios 223 enable 002 protection then hit a to start game I get red writing at the bottom saying Exception : [oct] error (DI_ReadID). I have just managed to get it to run with uloader gx is there a channel for this as letting the kids loose with the boot sd is not a good plan the 7 year old is a bit inquisitive but how else would we learn.
