Homebrew channel install problems
  • leebert
    • 28
    Hi Guys & Gals,
    I've got a problem with my own WII which i can't seem to sort out, Before i had this problem i was running on 4.1E with cioscorp 3.5, ciosrev15, When my 6 year old came in whingeing he couldn't play on the wii, when i looked at it the homebrew channel had gone & neogamma 8 had gone, & even more to my dismay, when i looked into settings it was now upto 4.2e!! i've since found out our 19 year old had a mate round & they wanted to play new super mario bros original & it asked them to update, which they did but she couldn't tell me why she also deleted hbc & neogamma afterwards, i've tried following the 4.2 guide to reinstall hbc using abd6a_v200 & abd69_v200, but it freezes. & abd6b_v200 came up with no vulnerable ios,
    Sorry it's long winded but it's really got me stumped I've done plenty of wii's but it won't even recognise nand & bootmi backup.
    Thanks in advance
    LeeBert
  • ck-ok
    • 2592
    have you got a nand backup and preloader installed?
    • leebert
      • 28
      Hi CK-OK
      Yes i have got nand backup & Priloader, But i can't access them!! Is there something to do with the update thats stopped them from loading?
      • ck-ok
        • 2592
        Originally posted by leebert
        Hi CK-OK
        4.2 does screw up your mod,have you tried holding in the reset button when you power up your wii?
        • leebert
          • 28
          Yes i'm afraid i've tried that. Without any joy
          • lirazoo
            • Mar 2010
            have you tried the downgrade option ?
            • leebert
              • 28
              From what i've read about. You cannot downgrade from 4.2!!
              • ck-ok
                • 2592
                4.2 update kills your homebrew and preloader, try this site How to fix "no vulnerable ios" error when installing HBC god luck
                • leebert
                  • 28
                  Hi CK-OK,
                  Sorry i've not replied before, as i've been on nights. Tried to fix the vulnerable ios. But still no joy. Am thinking now i may have to look into having it chipped. Thanks for your help
                  • ck-ok
                    • 2592
                    Hi CK-OK,
                    were not finished yet give this a try Bannerbomb - WiiBrew good luck
                    • leebert
                      • 28
                      Hi Ck-Ok,
                      That did the trick. First i went d/loaded, abd6a_v200. It came up with no vulnerable IOS installed, the other two just froze the wii. Then i went through How to fix "no vulnerable ios" error when installing HBC, & bob's you're uncle. I'm back up & running again
                      Thanks again CK-OK for your patience
                      Regards
                      LeeBert
                      • ck-ok
                        • 2592
                        Hi Ck-Ok,
                        Regards
                        LeeBert
                        now your up and running again make sure you keep wii connect 24 switched off and preloader set to block updates and use your perental controls
