I had to install the updated shop first, from the downloads section here, I think. Then I had to update a couple of the ios'es - but that was in the same download.
For me the 'trick' was to use the wad manager on a different ios - there is an option when you run the wad manager. I had to try a couple of options then it worked out fine.
