How to back your nand and install priiloader
  • dogtoffee
    • Jun 2009
    • 28
    Cut all files from you sd and store on pc for later
    unrar files to sd
    once you have files on sd
    *put it in Wii
    *click sd menu
    *load hackmii
    *install hbc
    *install dvdx
    *install bootmii as boot2 (if you can)
    *install bootmii as iso
    *reboot
    *goto hbc press home on the Wii remote launch bootmii
    *you will have 4 icons
    Use the power/reset/eject buttons to navigate the Bootmii menu
    select settings
    on the next page select back up to sd
    The back up takes about 10 mins and its normal to have a few bad blocks
    Put the SD card into PC and copy the NAND backup somewhere safe, you can now delete it from your card. If you installed Bootmii as boot2 then also copy the Bootmii folder to your PC .
    Now copy the original files back to sd
    [ame="http://www.youtube.com/watch?v=FPTpOCBYbzM&feature=player_embedded"]YouTube - Wii Soft-mod step2[/ame]
    Priiloader is a modded version of Preloader. just like preloader, Priiloader places itself in boot sequence before the system menu.
    You cant wright priiloader over preloader
    never delete ios
    If you are on 4.2 you need to have IOS70-patched.wad installed
    If you are on 4.1 you need to have IOS60-patched.wad installed
    Copy priiloader file to apps file on sd
    Then copy hacks.ini to the root of the sd card
    Go into HBC and select Priiloader, then load.
    Hold + and B to install
    Exit
    Go to Priiloader menu and select system menu hacks
    Then just enable skip disc update check and the region free ones
    Save then go into settings
    Autoboot = system menu
    Return = system menu
    Save.
    When checking Priiloader is working, power off and then on holding the reset button until Priiloader screen comes up make sure you can get into the HBC.
    Booting to USB loader GX
    *place sd card in pc
    *goto apps file
    *then to usbloader gx
    *copy boot.dol and paste to the root of sd
    *place sd card in wii
    *power off and then on holding the reset button
    *it will boot into Priiloader screen
    *click on load/install file
    *select boot.dol
    * A to install, once installed press B
    *go to settings
    *set Autoboot = installed file
    On boot up your wii will boot in to usbloader gx. I have read this works with configurable usb loader. But still have to confirm
  • short360uk
    • 313
    good thread! just 1 thing to add if bootmii can only be installed iso u will need a gamecube controller to navigate the menu power/reset/eject will not work most of the time
    • ck-ok
      • 2592
      allways worked for me
      • short360uk
        • 313
        lately ive found with factory 4.0 menu or over only gamecube controller works
        • ck-ok
          • 2592
          your proberly right as ive never done a wii with system menu 4 or higher
          • stucatz
            • Apr 2010
            • 86
            Hi guys, just tried to conduct a backup and when entered into bootmii IOS in priiloader, it comes up with message:
            could not find fat:/bootmii/armboot.bin.
            Any ideas?
            • short360uk
              • 313
              have u got the bootmii folder on the root of ur sd card
              • dogtoffee
                • Jun 2009
                • 28
                yeah m8 sounds like no bootmii folder on sd. if you follow tut in first post to the word you will be fine.
                • stucatz
                  • Apr 2010
                  • 86
                  no there is a boot.dol file, but not any bootmii files on the root
                  • ck-ok
                    • 2592
                    why not do it the way the tut says start hb channel and press home button and select bootmii
                    • stucatz
                      • Apr 2010
                      • 86
                      hi ck. i tried that and it just seems to go to a black screen and the disk drive light on the wii just keeps flashing blue so i presume it doesnt work. Hence may need to run it as a bootmii as IOS from priiloader but dont have the bootmii file in my root SD card.
                      • dogtoffee
                        • Jun 2009
                        • 28
                        m8 you must of removed bootmii folder after your soft mod if you follow the tut you will be able to do your back up.
                        • stucatz
                          • Apr 2010
                          • 86
                          thanks, but i dont really want to have to install it all again. I just would like to conduct the back up, by maybe adding a file?
                          • stucatz
                            • Apr 2010
                            • 86
                            All sorted thanks.
                            • kc57
                              • May 2011
                              • 10
                              Having the same problem, how did you sort it.
