Hi does anyone know if you can get microphones working when using usb loader to play the various singing games as the wii doesnt recognise them ?
microphones when using usb loader gx
Tags: None
first off plug the mic into your pc and make sure it works,and if it is and you cant get your mic to work by swapping usb ports,then you will need to get a powered usb hubsigpic -
Hi,
My microphone stopped working after I updated usb loader - you may need to reinstall ios 222 - once I did this it worked perfectly again.
The usb drive is on the right hand usb port, the mic on the left.Comment
usb microphone works perfectly with wiiflow but having problems with it working on uloader. all hit and miss. have wii 3.4 system menuComment
