crazy intro
  • nintendog
    • May 2010
    • 116
    crazy intro
    hi guys i was messing about on youtube last night and was wandering if any of you guys have moded the wii 4.2e to get the crazy intro to work were as the wii boots up it will play a short video before going to main screen or homebrew
    and when it tells you to place the info on the root of sd card does it meen to put in apps or just open sd and bang it on
  • ck-ok
    • 2592
    yes, ive used it put files on root of sd card means in no folder.
    • nintendog
      • May 2010
      • 116
      hi mate ive gone to this site and got crazy intro and it works wicked bit want to put my own clip on it can you point me in the right direction to were i put it and if i need to change any thing tarhttp://wiibrew.org/wiki/Crazy_Intro#Video
      • ck-ok
        • 2592
        X-Flak's Crazy Intro Video's - GBAtemp.net this site as a tut for making your own intro's and as loads to download
        • nintendog
          • May 2010
          • 116
          im strugling to get this to work any one fancy sorting this out for me im after this clip [ame=http://www.youtube.com/watch?v=NPm_9YWRKMA&NR=1]YouTube - The Dark Knight - "And Here We...Go"[/ame]
          going on this crazy intro Crazy Intro - WiiBrew
          i know its cheeky but im realy stuck many thanks
          • ck-ok
            • 2592
            can you post it as a video file?
            • nintendog
              • May 2010
              • 116
              unable to do this as when i attach video file it errors with saying mising token?
              is there another way to up load
              • ck-ok
                • 2592
                use winrar and turn it into a rar file then post as attachment
                • nintendog
                  • May 2010
                  • 116
                  hi mate ive atteched file hope it worked thanks
                  • ck-ok
                    • 2592
                    try this follow this guide for installing your own video X-Flak's Crazy Intro Video's - GBAtemp.net
                    • nintendog
                      • May 2010
                      • 116
                      ok mate i followed the guide and i can install crazy intro but when i try to install file for video it reverts back to the main start up screen
                      do i need top un rar the file or place the rar file on the sd under video thnaks mate
                      • ck-ok
                        • 2592
                        you need to unrar the file
                        -Edit your videos in the following folder SD:\crazyintro\videos\ (this can be changed by editing line 2 of crazyintro.xml)
                        -open the theme.xml file in the videos folder (SD:\crazyintro\videos\theme.xml)
                        -the contents of that file will look something like this
                        <?xml version="1.0"?>
                        <config version="1.8">
                        <properties>
                        <VideoFile filename="video1.avi;video2.avi;video3.avi"/>
                        </properties>
                        </config>
                        -the above settings will randomly pick from video1.avi, video2.avi & video3.avi (if a file is missing or incompatible with crazyintrovideo it will automatically boot the system menu (or whatever you have set to autoboot as in the crazyintro.xml, explained later). You can add and remove videos from that list as you please, just make sure to include the extension (.avi for example) and if you have multiple videos be sure to seperate the filenames with a semi-colon (.
                        if you have a video called video 1 already remove it or call it something else
                        • nintendog
                          • May 2010
                          • 116
                          hi mate im still getting no luck it its just not happening dude
                          • ck-ok
                            • 2592
                            have you changed the xml file?and put avi in the video folder?
                            is it still booting the old video?
                            • nintendog
                              • May 2010
                              • 116
                              im not sure what im suposed ro be changing as i can only copy in that file but not sure wgere in that file sorry i must seem thick
