alternate.dols pal
If it is Samurai warriors 3, it's a dual layer game, not an Alt.dol. Try loading it with 222/223. What are you loading ? Have you burned to disc, if so what type disc ?
-r's are recommended and set the layer break to 2084960 and try burning again at lowest speedsigpicComment
Well he hasn't been back since to give us an update to what doesn't work?
Samurai Warriors 3 not working fully in USB Loader GX (Dual Layer DVD ios help)
These user have tried 222/223 but it still doesn't work.Keith
2010 Golf GTD (170)Comment
Welcome to the forum.
Don't give us half the story which games don't work for you?
If the USB Loader works then its normally the IOS you are using.Keith
My Red Steel is NTFS but I don't have any problems playing it the same with Red Steel 2. I don't have The House Of The Dead but I have The House Of The Dead 2 And 3 Return but only 3 plays 2 just locks up with a black screen. I bought my own The House Of The Dead 2 And 3 Return and installed it on the drive and both 2 & 3 play.
See I do buy games if I like them.Keith
Medal of honr dol doesn't workhere is a bunch of alternate.dols
red steel
red steel2
wii sports resort
house of the dead 2 and 3
ssr blur
mortal kombat armgeddon
medal of honor heroes 2
indiana jones and the staff of kings
boogie
make a folder called alt-dol and extract the alternate.dols into it
then place on root of sd card.start your loader and set alternate.dol route to sd:\alt-dol
when you want to play a game that requires a alt.dol select load alternate.dol let the video play then when it crashes switch off alt.dol and reboot and game should now work fine.you only need to do this once.
if you want these for a different region just change the 4th letter to whatever your region isComment
The thing with Wii Sports Resort it checks to see if you have seen the tutorial video at the start and that logs in the save game. I have an original Wii Sports Resort which I deleted the save game and installed the game on the HDD but it wouldn't play. I played the disc then came back out and it played from the HDD.Keith
These generally aren't necessary any more as usb loader gx will search for the relevant alt.dol if you ask it to but you do needed to be connected to webComment
