Accidentally deleted IOS files Help ! please
  • MediaStar
    • Jul 2010
    I have accidentally deleted some IOS files while trying to softmod my Wii 4.2E.
    can these be reinstalled, if so could someone help with the method todo this. Any advice would be appreciated.
    Tried to load my original copy of Sports Resort and it's saying to upgrade.
    I also have a diskey installed does this make a difference.
    MediaStar
  • burro08
    • 59
    Dunno if it's the proper way to redo it bit when I did the same thing I just removed the sd card and formatted the hdd then started again and it worked
    K
    • costa
      • 204
      just download them off the net and start againe
      • ck-ok
        • 2592
        MediaStar
        run this Digital Kaos - Downloads - v4.2 safe firmware updater it will replace any ios's you have deleted,as for wii sport resorts just let it update it will be ok
        • MediaStar
          • Jul 2010
          Thanks for the speedy reply. I have done as you suggested and run the safe upgrade you supplied and let sports resort update, all seems to be working now.
          Just one more question, I still have HBC working but do I have to redo the softmod.
          Sorry to be a pain but this is my first time trying to softmod the WII.
          Regards
          MediaStar
          • ck-ok
            • 2592
            Regards
            MediaStar
            if you followed the tutorial right to the end then everything should be ok
            • mizzeeboy
              • Nov 2010
              hi i also but quite stupidely deleted all my ios files i tried going on adewii's website but it shut down what do i do?
              what did everyone else do?
              are there any downloads for the white wii 4.2e stub ios files.please tell me if there are thanks
              • ck-ok
                • 2592
                if your on 4.2 then try this Digital Kaos - Downloads - v4.2 safe firmware updater
                • 90coug
                  • Nov 2010
                  Originally posted by ck-ok
                  What is your on 3.4 ? Will this still work?
                  • ck-ok
                    • 2592
                    if you run this you will end up on 4.2 but you will still have the hb channel and a fully modded wii.
                    • Subbynet
                      • Nov 2010
                      Excellent - just what I needed. Thanks.
                      • Rupesh Ghadiali
                        i have a black wii with firmware 4.2e, can i still use this
                        • Dai2000
                          • Jan 2012
                          • 8
                          Please help! i accidentally uninstalling a WAN file "System Menu-NUS-4.1u-v54449.wad", I still have that file on my SD card. I am not sure if this is what you called uninstalling IOS? Turn on the Wii has power (green light - NOT booting with a black screen). Again, turn the Wii while holding down reset button for a minute still does not do anything. I have had try run Digital Kaos - Downloads - v4.2 safe firmware updater still no go with a black screen on TV.
                          Region: NTSC-U
                          System Menu 4.3U (v513)
                          Hollywood v0x11
                          Boot2 v4
                          Priiloader_v0_7
                          • ck-ok
                            • 2592
                            Region: NTSC-U
                            Hollywood v0x11
                            Boot2 v4
                            Priiloader_v0_7
                            i think you mean a wad file.
                            plus you ran 4.2 updater when you on 4.3
                            try running Digital Kaos - Downloads - 4.3b safe firmware updater
                            what is happening with the console is it still booting to system menu is it still playing backups?
                            • Dai2000
                              • Jan 2012
                              • 8
                              Add to my foot note above HBC 1.0.8.
                              Yes I mean a WAD file. I was on 4.3 until I downloaded the WeHackWii Package and began Softmodded, it downgrade to system menu 4.1 (dont know why). At later time I upgraded back to 4.3U, and everything still working perfectly fine.
                              Truly this is what happened. I was trying to install WiiFlow forwarder channels with WAD-Manager_v1.7_Full.
                              System Menu-NUS-4.1u-v54449.wad (included in this WAD folder too)
                              8Bits-FIX94v11forwarder-DWFA.wad
                              Carbonik-FIX94v11forwarder-DWFA.wad
                              Default-FIX94v11forwarder-DWFA.wad
                              Green-FIX94v11forwarder-DWFA.wad
                              Nihonflow-FIX94v11forwarder-DWFA.wad
                              Orange-FIX94v11forwarder-DWFA.wad
                              Orchid-FIX94v11forwarder-DWFA.wad
                              StarNight-FIX94v11forwarder-DWFA.wad
                              Violet-FIX94v11forwarder-DWFA.wad
                              While trying out each different channel forwarders to see which one that I liked most, after I installed about the fourth time getting ERROR! (ret = -1035/2011). Ok, maybe I installed too many channel forwarders and so started uninstalling them. It works! I would be able installing channel forwarder again without getting ERROR!
                              At this point, I know which channel forwarder that I like, again getting ERROR (ret = 1035). Okay, lets start uninstalling them again. Unfortunately, this time I selected (System Menu-NUS-4.1u-v54449.wad) the wrong wad file. It took me back to the HBC and then freeze, reboot with black screen.
                              Answer to your question what is happening with the console is it still booting to system menu? The answer is NO. I dont think its a fully brick (I have BootMii installed (as boot2), the Wii displays nothing and I am presented with a black screen. Power still come on, I would be able to insert CD disc and ejected. Thank you so much ck-ok for any inputs and advise that you may have. Best regards, Hugh
                              p.s. trying to run Digital Kaos - Downloads - 4.3b safe firmware updater does not do me any good and presented with a black screen. Sorry!
