Lego Harry Potter 1-4
  • DingoTest
    • 19
    We have just bought Lego Harry Potter 1-4 from Amazon but when we insert the disc it wants to do a System Update??
    Does it just want to install a later version of IOS56 or is it trying to install System Menu 4.3?
    TIA
    DT
  • ck-ok
    • 2592
    TIA
    DT
    there is no disc containing 4.3 at the moment.
    try installing preloader so you can block disc and online updates,follow instructions at bottom of this post http://www.digital-kaos.co.uk/forums...loader-109168/
    • DingoTest
      • 19
      Preloader/Priiloader definitely seems the way to go.
      • DingoTest
        • 19
        Incidentally how do I determine what IOSes are present in the update area of a disc?
        Is there a tool for this?
        • ck-ok
          • 2592
          try this Digital Kaos - Downloads - wiiscrubber
          • DingoTest
            • 19
            Cool. Will try that sometime. Of course I have an original disc not an .ISO so I might need to do some jiggery pokery.
            Back to topic...
            I put priiloader and hacks.ini on an SD card in apps and root respectively. And then ran priiloader installer and it appeared to successfully install but when I restarted it went to the Health and Safety screen and then System Menu.
            No sign of priiloader... Did I missing something obvious?
            TIA
            DT
            • ck-ok
              • 2592
              no it just runs in the background if you want to know what ios and system menu a game uses try this Which IOS Games Use To Run
              • DingoTest
                • 19
                DOH. It was working all the time.
                Pressing RESET whilst Powering ON showed up the menu and allowed me to Enable some options. i.e. No Online or Disc updates.
                Regards
                DT
                • DingoTest
                  • 19
                  I looked a bit closer on the disc update area and can see...
                  WiiSystemMenu-v482.wad and numerous IOS updates
                  So it includes what I think is 4.2E update only.
