  • royboyz
    • 205
    #16
    right will do that tomorrow, packed up for tonight, thank you very much for the help you are giving. Its very much appreciated.
    • royboyz
      • 205
      #17
      deleted the red one so now i only have the blue one Cheers
      got into installer, which ios do i choose ?
      when i choose that next screen has 4 custom install slots
      (1) Install Custom IOS 202 v65535 (homebrew)
      (2) Install Custom IOS 222 v65535 (Default)
      (3) Install Custom IOS 223 v65535
      (4) Install Custom IOS 224 v65535
      Press A to select or B to Abort
      Current IOS: 249 v17
      Dont want to go further as im scared to bugger it up
      • ck-ok
        • 2592
        #18
        install all of them
        • royboyz
          • 205
          #19
          Which IOS base do I choose is it the 38 recommended?
          I went with 38 downloaded & installed ok
          So is that done now. Just download games and run through wii USB loader?
          • renke_uk
            • 53
            #20
            Now then,
            Have you installed the USB & Gamma channel forwarders?
            SoftMod Essentials:- Dop-Mii V12 --- CFG USB Loader FAT32 --- Wii Game Manager
            • royboyz
              • 205
              #21
              not sure? is it an icon on my main screen? i have Neogamma, wii USB loader, usb loader gx, load mii and homebrew channel
              On the plus side I Opened usb loader and chose my pen drive which i formatted to wbfs and i was able to add a game through the disk drive, however my pen drive is only 8gb, i so wish i had created partitions on my 1tb hdd
              But at least i managed to do something, play a game without the disk!! which is something i couldnt last week!
              • ck-ok
                • 2592
                #22
                your all set then enjoy
                • renke_uk
                  • 53
                  #23
                  Sounds like they are there NeoGamma & CFG
                  What format is your Hard Drive?
                  • royboyz
                    • 205
                    #24
                    how do i get the game onto my hdd cos its in fat32?
                    when i open up usb launcher its says no wbfs partition.
                    Is it through game manager? iso.files??
                    fat32 and its unpartitioned
                    I assume neogamma is for if i want to burn games to dvd and play through that? if thats the case i have downloaded imgburn also
                    • renke_uk
                      • 53
                      #25
                      there are 2 main game formats, .iso (that you put on a WBFS Partition) and .wbfs (that you put on a FAT32 Partition.
                      To use fat32 you need to have installed cIOS222/223 - which you have.
                      Create a WBFS Folder on the Hard Drive
                      Use Wii Game Manager to convert & copy your .ios to the Hard Drive. (check my sig)
                      For the copy options your lookin for 'create with subdirectories,4GB Split'
                      Once you done one it's a doddle.
                      I'm back this afternoon if you want a walk through
                      Regards
                      • royboyz
                        • 205
                        #26
                        Done that, when i open up CFG usb loader choose HDD it still says no WBFS partition found create or abort
                        Im off to work now, then playin footie so will be on around 9.30 tonight.
                        Thanks for the info
                        Cheers
                        • renke_uk
                          • 53
                          #27
                          Sounds like you not using the right boot.dol for FAT Drives
                          Download the latest CFG FAT32
                          Extract and copy to the root of your SD card
                          Regards
                          • royboyz
                            • 205
                            #28
                            Copy all the files from that download or just the boot.dol?
                            • renke_uk
                              • 53
                              #29
                              All of them
                              • royboyz
                                • 205
                                #30
                                highlighted them all and extracted them to my sd card.
                                Root of SD Card now has following:-
                                apps
                                PCApps
                                usb-loader
                                bootmii
                                ios
                                prboom
                                private
                                Wad
                                boot.elf
                                bootmini.elf
                                installer.log
                                boot.dol
                                tried again but still no joy getting same message
