priiloader wont run/install
  • roryson
    • Mar 2009
    • 694
    gone through dogtoffe's guide to install priiloader, i ran it in THC and installed it. then it says go to priiloader menu and select system hacks.. the problem is i cant find the Priiloader menu.. any help people.. would be verry greatfull...
  • ck-ok
    • 2592
    hold in the reset button while powering up
    • Jolicina
      • Jul 2012
      I have a similar problem. I've tried to install several versions of priiloader but everytime my controller hangs. Tried with an older controller as well but still won't work. Using the power, reset and eject buttons on the wii also don't work.
      What am I doing wrong why can't i install priiloader?
      I'm on firmware 4.3e
      Thanks for any help.
      • Keithuk
        • 2264
        Does it show any errors when you install PriiLoader apart from can't find password file which you ignore?
        Now the PriiLoader v7.0 in the download section is ok but its missing 1 or 2 ini files. Even if it does install when you run it it will say hack.ini is missing and maybe hacks_hash.ini, this needs to be on the SD card root. I'm surprised that CK has missed that out.
        Even when the Wii has started up you can access PriiLoader if you press the Reset button for a couple of seconds.
        Keith
        2010 Golf GTD (170)
