nand backup with bootmii
  • billy2
    • 1381
    hi all cant back up my nand with bootmii the rc stop working can anyone tell me what i need to do please ???
    please press the little red THANKS tab
    if I helped if not press the green tab to tell me to f**Koff
  • billy2
    • 1381
    ok i see i need a gamecube controller is this true ??? or can i do this some other why , so far i have only put homebrew and bootmii as am ios this is all it would let me use
    cheers
    • mrgasman
      • 668
      cheers
      The reset, power and eject buttons on the console can be used for selection m80
      • billy2
        • 1381
        thanks m8
        right guys iam as far as here and do i need to install this (my wii is (4.1e)
        5. THE FINAL STEP
        Priiloader is also an optional install, if you don't want it just skip b & c, but you must do step d, system menu hacks can be taken care of by Starfall (3.2) or startpatch (4/4.1), if you want them click my sig and have a look through my mediafire. There are no system hacks for 3.3/3.4.
        a) If you are on system menu 4/4.1 use Wad Manager with default settings (IOS249 & SD card) to install IOS60-patched.wad - make sure you do this before you install Priiloader. If you installed it in step 4 then skip this part. Never uninstall IOS60! You will brick!!
        b). Open the Homebrew Channel and load Priiloader, press + to install. After install, your Wii should reboot and load the Priiloader menu. If it doesn't, turn your wii off and on again whilst holding down reset and it will load the Priiloader menu.
        c) Select 'system menu hacks' in the Priiloader menu, and enable the hacks that you want - 'skip disc update check' and the region free ones are all you need. Select 'save settings' and wait for confirmation message to display 'settings saved'. Press B to go back, and enter Settings. Set 'Autoboot: System Menu' using D-Pad, then select save settings. Press B to return to main Priiloader menu.
        d) In the Priiloader menu select Homebrew Channel (if you didn't install Priiloader then just open HBC as normal), run Wad Manager 1.4, use default settings (IOS249 & SD card) and install these wads from the 'wad' folder:
        IOS38-64-v3867
        IOS50-64-v4889
        IOS53-64-v5406
        IOS55-64-v5406
        Neogamma Channel - R8
        Then restart your Wii.
        All done! You will now have the safety/hacks of Priiloader & Bootmii, NeoGamma R8 backup loader that has 99% compatibility, cIOS249 r17, IOS38, 53 & 55 for newer games and IOS50 to help prevent disc update bricks. If you ever need to access Priiloader's settings hold down 'reset' when switching your Wii on.
        If you get the 'system files corrupted' screen don't panic, just reinstall preloader and if that doesn't fix it reinstall your current system menu with Wad Manager.
        • short360uk
          • 313
          yes mate u need to install everything make sure u install the ios-60 patched wad before u install priloader then install the last 5 wads and ur done
          • short360uk
            • 313
            make sure u block online and disk updates in the priloader menu. to access priloader power up th wii and hold reset button
            • billy2
              • 1381
              ok guys been following New 3.1-4.1 Softmod for ANY Wii guide so far all going well i think, down to stea 4 now and could do with some help from here on in iam on (4.1e) do or do i not do step 4 ???
              4. UPDATE YOUR SYSTEM MENU VERSION
              Warning - If you don't install the patched IOS60 first you will brick!
              This step is optional unless you are on 3.1, 3.3 or 3.4 in which case you must update, if you are on 3.2 or 4.0 you can update if you want and it is recommended that you do, if you are on 4.1 there is no need obviously! If you are on 3.1 you will have to update to 4.0 first, make sure you install the patched IOS60 first though still. Before you update to 4.1 make sure you have at least 250 blocks free or you will brick, install IOS60-patched first with Wad Manager using IOS249, then run Firmware Updater 4.1. If you are on 3.3 or 3.4 then you must update now - DO NOT install priiloader until you have updated as it will cause untold problems!.
              • ck-ok
                • 2592
                your on 4.1 theres no need to update
                • billy2
                  • 1381
                  thanks for your reply m8 did i need the ios-60 patched installed ???
                  cheers
                  • ck-ok
                    • 2592
                    cheers
                    yes you do
                    • billy2
                      • 1381
                      all done thanks guys for all you help ,how can you guys tell me the best why to back up games ?? so i can try this on a usb key
                      also is there any other bits i need to put on the wii at some time i will be using a hdd but for now its a usb to test
                      cheers
                      • short360uk
                        • 313
                        the easiest way is to download the games mate, there is always bits to install for certain games and such and but u should br pretty much upto date at tho mo. just keep checking the forum
                        • billy2
                          • 1381
                          thanks m8 will wii flow back up games ???
                          • ck-ok
                            • 2592
                            yes all usb loaders will backup your games
                            • billy2
                              • 1381
                              thanks again m8 i have installed usb loader gx as there a guide to this backup to harddrive as i cant seem to find one ??
                              thanks again for your time guys
