4.3e wont play backups anymore
  • southbrook
    • 97
    Hi Peeps...firstly sorry if a repost...cant seem to find same symptoms on other threads...... my mate soft modded his 4.3e with indy pwns hack. installed priiloader and blocked disc and net updates. Then installed wiiflow and added the forwarder for it.
    A couple of days a go he got tiger 11....his lad has played it off the original disc fine. He tried to fire up wiiflow to backup the game to his hdd but wiiflow just sits on a black screen after he starts it? I nipped round to look and also checked usb loader x- same result... tried a backup disc with neogammer -same result ..... checked HBC - still present and fires up fine. Finally checked to see if wiiflow runs from HBC - same black screen?
    Any advice will be greatly received.
    OOPPS forgot to mention...he has played loads of games from hdd with no probs previous to this
    PSN id RISSIEN
  • southbrook
    • 97
    just a quick update..... tried to install cios38-rev17 but freezes and remotes will not connect...... tried through wad manager but still freezes saying "mounting drive.....please wait......"
    Then tried to do a nand backup but bootmii throwing up an error saying cant find a .ini file
    Any ideas?
    thanks in advance
    PSN id RISSIEN
    • reddevil157
      • 1427
      [QUOTE=southbrook;782897]just a quick update..... tried to install cios38-rev17 but freezes and remotes will not connect...... tried through wad manager but still freezes saying "mounting drive.....please wait......"
      Any ideas?
      thanks in advance[/QUOT
      should that be " hacks.ini " file ?
      • southbrook
        • 97
        sorry yep Hacks.ini file......
        thanks for reply
        PSN id RISSIEN
        • ck-ok
          • 2592
          thanks for reply
          sounds like a sd card problem,have you tried reformatting itor using a different card
          • reddevil157
            • 1427
            Take a look here, make sure you get hacks.ini to match your system menu. wiibrew.org/wiki/Preloader/hacks
            • ck-ok
              • 2592
              hi reddevil he should also have a .ini file in his bootmii folder,perhaps he's took his bootmii folder off the sd card .if thats the file he needs then its in the bootmii folder of the 4.3 mod download
              • reddevil157
                • 1427
                I didn't think of that ck, your spot on as usual m8.
                • southbrook
                  • 97
                  thanks for the reply peeps...much appreciated... i'll report back with results.... would it help if I post the results of syschek to show what ios's are installed etc? Also if all else fails is there a way to update the wii and redo the softmod in a safe manor?
                  thank you
                  PSN id RISSIEN
                  • rjbweb
                    • 23
                    thank you
                    I sounds to me like a prob with the hdd no with the wii... tried to conect the hdd to the pc and acces it with wbfsmanager?
