games i cant get to work on usb
  • ck-ok
    • 2592
    #16
    Originally posted by billy2
    thanks for your reply m8 i have tryed them and cant get to work this is what i did
    1 download the dol (as in link)
    2 extract all dols to a folder called alt-dols
    3Run the loader, and change the custom path for alternate dols to...SD:\alt-dols\
    4 start game in the settings on the loader fpr game i have 3 to choose from , alternate dols,load from sd/usb or select a dol i have tryed all of them when i choose sd/usb i get error sd:/alt.dols/ rm2e69.do; dose not exist you messed something up idiot . when i look inside alt-dols folder i see all 9 dols there so i know there in the folder
    i dont even get to video play screen goes black
    when i select
    cheers
    change the 4th letter of the alt.dol from p to e save and try again
    • reddevil157
      • 1427
      #17
      Don't forget to tell us if it work's, it will help other ppl.
      • billy2
        • 1381
        #18
        no m8 not working here is the folder with dol in it, what i did was add RM2P69 and added RM2E69 tryed it with ios 222,223,and 149 also tryed it with NeoGamma and disk and still no joy
        please press the little red THANKS tab
        if I helped if not press the green tab to tell me to f**Koff
        • ck-ok
          • 2592
          #19
          what loader are you using? try putting just the alt.dol you want in the folder as most loader will only recognise 5 .dols select use alt.dol option in loader and start it from there for the first time.
          • billy2
            • 1381
            #20
            thanks for your reply m8 using usb loader gx r919 will remove all dols and try do you know what ios this game works on ??
            cheers
            • ck-ok
              • 2592
              #21
              [quote=billy2;794629]thanks for your reply m8 using usb loader gx r919 will remove all dols and try do you know what ios this game works on ??
              if you still dont have it working hover your curser over the game check its six digit number and make sure that corrosponds to the alt.dol and recheck the path for the folder
              • billy2
                • 1381
                #22
                ok m8 just had a look in wbfs as curser over the game only giving me the name, in wbfs it is saying it is an ntsc game and RM2E69
                • ck-ok
                  • 2592
                  #23
                  try choosing alt.dol from disc in settings and it should scan the iso for .dols and select game.dol and launch that also try reading this http://gbatemp.net/t149922-usb-loade...&#entry2057212 post 6383
                  • billy2
                    • 1381
                    #24
                    thanks m8 in the post it saying i need to have cIOS38_rev13a installed do is i need to use that one or is this a better one to use Digital Kaos - Downloads - cios38 rev17 also how do i use it m8 ???
                    getting a pain in the ass for 1 game this is
                    thanks for your time m8
                    • ck-ok
                      • 2592
                      #25
                      use rev17 it only says rev13 cause its a old post,just install as it says on download page and your wii will run on that automatically,then follow rest of tut in the link
                      • billy2
                        • 1381
                        #26
                        ok giving up on this game now tryed the lot
                        how i find out that manhunt2 is not working gets to the loading stage and freezes on loading
                        • reddevil157
                          • 1427
                          #27
                          Right,I d/l that medal of honour heroes 2, it loads with ios 222, alternate dol is default, 002 fix is anti. USB loader GX rev937, cIOS 249 rev 17, I d/l a ciso file, I also use wii backup manager to transfer my file's, not sure if this matter's, worked no problem. I'll compare your sys check to mine later on and get back to ya.
                          Red.
                          • billy2
                            • 1381
                            #28
                            m8 this loader is giving me nothing but shit m8 now more games have stopped working,iam running r919 now tryed to do online update and its saying there is no update ??? also having probs running games on NeoGamma from usb mario kart was working last week not now super monkeyball was working last week not now and thats on usbloader and NeoGamma have done nothing new to the sd card over the week so dont know whats going on
                            cheers for your time
                            • ck-ok
                              • 2592
                              #29
                              try downgrading your hermes 222/223 to v4 perhaps v5 is causing probs you can just install over v5 Hermes' Ios222/223 - GAF's Wii Homebrew Tutorial
                              • reddevil157
                                • 1427
                                #30
                                Right , firstly, you seem to have more ios'es than me, lower one's that is, nothing to worry about there. Secondly, when you installed 222/223, did you also have 202 with the install, I did, now don't worry, as far as I'm aware 202 was mainly to make MPlayer CE .75 run faster ( movie's ). Only other difference is, I've got ios 70 patched, free the wad or something, it's that long since I installed it, not sure about this, you'll have to ask CK, don't know if it would make a difference. What sort of file was your copy of medal of honour?
                                Usb gx, do you use a forwarder or channel ? Could just have been a bad download or somehting of gx. What file's do you normally d/l ?
