Zelda mod
  • skegsagypsy
    • Aug 2009
    • 1230
    Zelda mod
    A friends zelda modded 4.2e wii has stopped working, the homebrew channel has also disappeared, not sure if his kids have done an update with a disc, but it's not connected to the net so it hasn't been updated otherwise. Any ideas what to do, can I just re-install homebrew, or would I be better trying a new cios, failing that should I redo the wii with the latest mod ?
    'If you are neutral in situations of injustice, you have chosen the side of the oppressor. If an elephant has its foot on the tail of a mouse and you say that you are neutral, the mouse will not appreciate your neutrality.'
    -Bishop Desmond Tutu
  • ck-ok
    • 2592
    sounds like its been updated to 4.3e if so your going to need to remod with http://www.digital-kaos.co.uk/forums...-3-mod-157379/ check in wii settings for system menu number
    • skegsagypsy
      • Aug 2009
      • 1230
      It hasn't been updated. the wii is still on 3.2e, would it be best to hard reset then re-do the softmod ?
      • ck-ok
        • 2592
        is the wii 3.2 or 4.2 as you have different numbers in each post.
        if you dont have a nand backup then try reinstalling homebrew again if that dont work just remod it, and theres no need to hard reset it just remod it
        • skegsagypsy
          • Aug 2009
          • 1230
          OK Thanks
