Wii Questions - 4.2e
  • jamesjea
    • 10
    Hey guys,
    Just got a Wii it is on 4.2e.
    If i follow the soft mod guide shown here; click
    Will i be able to download Wii iso files and burn them to a DVD-R and play then straight on the Wii without an external HDD Purchase?
    Also, if that is true, is there a guide on how to back up/burn Wii games?
    Thanks folks.
  • ck-ok
    • 2592
    Originally posted by jamesjea
    Hey guys,
    Thanks folks.
    check your serial number here Wii Drive Chip Database to see what drive you have.
    the tut your going to use is the same as the one here http://www.digital-kaos.co.uk/forums...w-guide-67927/ except hes added videos.
    • jamesjea
      • 10
      Hello,
      I will check my serial in next 30 mins but thanks in advance, i will check the tutorial out.
      Also, once sorted, will i require a USB HDD or can i burn the games to disc some how (is there a guide?) and do it that way, as i have millions of blanks lying around!
      Thanks a bunch
      • jamesjea
        • 10
        Serial number: LEH176413086
        The Wii has a RVL-001(EUR) model number and is produced for the European market. The copyright year is 2006.
        There is a 100% chance the chipset is GC2-D2C (v1).
        That is serial
        • ck-ok
          • 2592
          That is serial
          you should be able to play dvd backups. you can't rip games on a pc unless you have a certain lg drive. for burning your games use imgburn just google it its free this will show you how to use it Burning Your Game Backups .
          • jamesjea
            • 10
            Hey,
            Thanks!
            So i can go ahead and do this: Wii 4.2E Load Backup Games from USB HDD | Rob Mulally
            and then it will be ready for me to play a game i will be putting onto disc as soon as it is downloaded?
            As simple as putting the disc in and playing?
            Thanks, sorry i am so new!
            edit:
            First, make sure that before following this tutorial that you have a modchip installed. If you do not: "This Will Not Work"
            ah! - that means i need an external HDD right? I thought i would have been able to play from discs
            (http://www.wiihacks.com/other-faq-gu...e-backups.html)
            • ck-ok
              • 2592
              Hey,
              Thanks!
              edit:
              (Burning Your Game Backups)
              you can play without the modchip that tut was for non soft modded wiis,but the burning of the iso is the same,yes start modding
              • jamesjea
                • 10
                Will get back to you tomorrow and let you know how it went. :-)
                Thank you so much for your help, every thread i have read over past two hours it has been you helping out.
                Appreciated greatly.
                • ck-ok
                  • 2592
                  no problem,make sure you use quality dvd-rs like verbatim
                  • jamesjea
                    • 10
                    Alrite to do my first test on a normal cheap 'Asda' DVD-R though?
