How do i update my softmodded wii?
  • daviethistle
    • Oct 2010
    • 8
    I've not used my Soft Modded Wii for a long time and wondered if someone could tell me how to update it? It has homebrew channel etc loaded and i used wii backup manager to load backups of games from disc previously however this does not seem to work with latest games. Wii Party for instance. Is there an easy updater i can use to let me play the latest games? Currently at version 3.3E.
  • ck-ok
    • 2592
    install these Digital Kaos - Downloads - cios38 rev17 and http://www.digital-kaos.co.uk/forums...-final-104295/
    • daviethistle
      • Oct 2010
      • 8
      thanks for that, one slight problem. My OH decided to update the wii while ii was out and now i'm at version 4.3E.
      What now? I still have homebrew channel but wont load anything just blank screen! Help please.
      Cheers.
      • ck-ok
        • 2592
        Cheers.
        if your homebrew channel is still working then it wont be to hard to get running again follow this http://www.digital-kaos.co.uk/forums...-3-mod-157379/ tutorial from after installing homebrew,if your homebrew channel is not working then your gonna need to fully mod it again with same tut.
        oh yeah dont ever let the OH near it again !
        • daviethistle
          • Oct 2010
          • 8
          Thanks for your responses ck-ok, i've now tried to do the tutorial from after installing homebrew channel.
          ie...format sd card again and extract modpack from the folder you downloaded earlier to sd card
          run md5summer.exe and click verify sums and check theres no errors.
          When i press 'home' from homebrew channel and then select 'BootMii' the screen just goes black and nothing happens. I assume i'm onto a loser and need to get myself a copy of the Lego Indiana Jones game and start from scratch???
          Argh!!!!!!!!!
          • ck-ok
            • 2592
            Argh!!!!!!!!!
            when you start h/b channel does it show any apps that are in the apps folder?
            • k-worth
              • Oct 2010
              keeping softmodded Wii updated
              So the best way to keep a softmodded Wii updated is to look for the latest releases of these two apps?
              Thx,
              k-worth
              • daviethistle
                • Oct 2010
                • 8
                Think i may have got some progress. On the Wii menu i now have:- The homebrew channel, my original backup launcher, usb loader, Neogamma Channel and LoadMii.
                When i go into Homebrew Channel i have :- USB Loader GX, Hackmii Installer, NeoGamma and Priiloader.
                I can get a couple of my older backup games on dvd to work using Neogamma but an old tiger woods 2010 that worked using backup launcher will load so far then just stop.
                Am i better to concentrate on just using USB Launchers now?
                Thanks again ck-ok.
                • ck-ok
                  • 2592
                  Thx,
                  k-worth
                  no there are newer ios38's but this one is more stable,but there is newer neogammas but the only improvements in that is the playing of game cube backups
                  • ck-ok
                    • 2592
                    Thanks again ck-ok.
                    have you followed the 4.3 tut from after installing homebrew?
                    have you got the motion plus plugged in?
                    • daviethistle
                      • Oct 2010
                      • 8
                      yeah i followed it step by step, and i dont own a motion plus.
                      Just trying to find if i'm using the correct settings for the neogamma launcher. I dont have a spare usb hard drive to use so i'll have to buy another one to just start using the usb loaders. Hopefully they will work.
                      • ck-ok
                        • 2592
                        try playing it through uloader http://www.digital-kaos.co.uk/forums...taller-143444/ you dont need the cios installer you already have that. when you start uloader it wont detect a usb so it will go into disc mode,if that dont get it working you can still use it when you get a hdd
                        • daviethistle
                          • Oct 2010
                          • 8
                          cheers, i'll have a go at that and let you know.
                          • daviethistle
                            • Oct 2010
                            • 8
                            right i tried uloader which i got installed and run no probs but when i put in tiger woods 2010 it froze on the loading screen then went black and had this message "The game disc could not be read. Refer to Wii operations manual for details"
                            Aint got a clue whats going on. You'll be getting fed up with me replying all the time with more issues. Apologies.
                            • ck-ok
                              • 2592
                              try giving the disc a good clean and try and clean the laser with a lens cleaning cd,if that fail copy the backup with imgburn and reburn it
