we sing
  • dingledangle
    • 528
    we sing
    how do you get 4 player on we sing,where to get adapter
  • ck-ok
    • 2592
    dont know if you already have 4 mics,but i have seen 2 mics on ebay with a 4 port adaptor included
    • dingledangle
      • 528
      cheers,i have 2 mics and play games using wiiflow,so i just need an adapter to let you plug in 2 or more mics into 1 usb input.
      • ck-ok
        • 2592
        USB AUDIO microphones ADAPTER CONNECTOR for Wii Xbox360 on eBay (end time 17-Nov-10 06:14:55 GMT)
        • dingledangle
          • 528
          cheers mate but it seems to be the adapter for the singstar mics,the inputs are jack inputs,i need the 1 with usb inputs.
          • dingledangle
            • 528
            or is there any disk loaders that will run 223.
            • ck-ok
              • 2592
              • dingledangle
                • 528
                thanx ck-ok,will give it a go and report back.
                • dingledangle
                  • 528
                  everything worked fine until about 30 seconds into a song and then froze,guess ill just av to play 1 player,cheerz for help ck-ok,much appreciated
                  • billy2
                    • 1381
                    can you not use wireless microphones ??? or doos it have to be usb
                    • ck-ok
                      • 2592
                      have you tried just using a multiple usb hub?
                      • dingledangle
                        • 528
                        no mate,av not tried the wireless mic as av only got wired.spoke to a bloke at gamestation and he recomended the rockband usb adapter,tried it but didnt work.will try a normal usb hub.cheerz.
                        • dingledangle
                          • 528
                          got a usb hub from poundland and worked on we sing but now we sing encore wont load in wiiflow or uloader,will av to do some tampering,cheerz guys for input.
                          • ck-ok
                            • 2592
                            do you get a error or a coloured screen?
                            • dingledangle
                              • 528
                              no mate,just got it sorted,reinstalled 202,222,223 and away it went.but i just noticed if i leave the hub in and load up gh6 it doesnt load but loads fine when 1 mic is plugged in.anyways im well chuffed only cost a quid to sort and just in time 4 xmas,once again thanx for input and advice,very much appreciated.pukka
