just on the tutorial but stuck at this
7. Press down so Remove stubbed IOS is selected then press A. When asked to check for stub IOSs press A. A number of stub IOSs will be discovered. Press B for ?NO? for all IOS files except 222, 223, 249 and 250. Which you should press A to confirm deletion of. Press B for all other IOSs. When the discovery of stub IOS is complete you will be sent to the MMM menu. If you were not asked to remove 222,223,249 or 250 move to step 7.1. Otherwise to continue to step 8
i dont have those 222,223,249 or 250 anywhere
so i continued like it said but at this stage..
9. Press 1 to select all the wad files in the folder, then press A to continue.
If you get any install errors with the above wads, try step 7.1 above and then try again.
but it still says the same errors what should i do
