Can't load LoaderGX Exception (DSI) occured
  • tulumbe
    • Nov 2010
    Hi all,
    gotta problem with soft modded Wii, can't load HBC and USBloader GX.
    Worked flawlessly for 8 months but now:
    starting HBC from Boot Mii causing black screen only,
    trying to start HBC from Wii menu got me back to Wii menu again and
    if I try to start USBloader from Wii menu, have massage "Exception (DSI) occured".
    Not shore if kids erased something using HBC, but doubt it.
    BootMii installed as boot2, I do have nand and key backup, and ver. 4.2E present, as when modded.
    Can I do safely all the mod procedure again, or there is no need and some smarter advice?
    Thanks a lot!
  • ck-ok
    • 2592
    Originally posted by tulumbe
    Hi all,
    Thanks a lot!
    are you sure your still on 4.2?
    if you are then just remod it again following this http://www.digital-kaos.co.uk/forums...w-guide-67927/
    • tulumbe
      • Nov 2010
      Wow, thanks Ck-Ok for swift reply, will remod it, and post the result.
      • tulumbe
        • Nov 2010
        Did all successfully, but had a problem with point 7.1.
        Couldn't install ioses and Uloader, using wad manager
        in MMM pack, showing error2011,
        but Yet Another wad Manager installed them all.
        Another question is how to manage slots in wii menu, to move channel in gaps left by erased channels?
        Ck-Ok, my kids thank you too!
        • ck-ok
          • 2592
          hover over the channel you want to move press a and b button together and drag to wherever you want then let go
