Installing the Backup Loader Hack -
  • dowlinr
    • 226
    I'm was getting cheesed off with all this chip talk so decided to update some instructions a friend wrote and put everything needed in the one zip file.
    Anyway here's the instructions you will need.
    Edit:
    These Instructions are for people who haven't updated to 3.4. If you have you will need a new version of the Twilight hack, it can be downloaded from http://wiibrew.org/wiki/Twilight_Hack#Download
    __________________________________________________ ___________________________________
    Step 1 - Preparation
    Before you embark on your quest to soft mod your console, you'll need the following -
    A Wii Console
    Legend of Zelda - Twilight Princess (Wii Version!)
    An SD Memory card (anything from 32Mb up to 2GB)
    An SD card reader
    First of all, download this file
    backuplauncher_0.3_gamma.zip
    and extract it to your HD.
    Format your SD card in the FAT format. Copy the contents of the "backuplauncher_0.3_gamma" directory to the root of the SD card
    Step 2 - Installing the Twilight hack
    Put your SD card into your Wii.
    1)Now, Start by playing Zelda if you haven't already and save the game. For some reason you are unable to copy over a save game unless you've played it before. So play, save, exit to Wii menu.
    Open up the data management screen and delete your newly created save game. Then, whilst still in data management open up your SD card and copy the correct "twiglight hack" save game for your region onto your Wii.
    rzdp = Europe
    rzdj = Asia
    rzde = USA
    (Note - some Wii's won't see the save game. If this is the case, whack the SD back in the PC, find the data.bin file, right click and then tick the archive bit).
    Once the save is transferred, load Zelda again, and load the twilight hack save game. When it loads, run forward and speak to the man infront of you. This will now proceed with the installation of the homebrew channel (as you put that in the root of your SD card, right?).
    Now you have the homebrew channel as a permanent fixture on your Wii desktop.
    Installing the loader
    Open the homebrew channel, and open the CIOS installer. This needs the wii to be connected to the internet (wireless or wired) as it downloads the required files. Once installed (takes around 5-10 minutes) you can run the Backup Loader but you don't want to have to go into the Homebrew channel every time you want to load a backup so read on.
    __________________________________________________ ____________________________________
    Installing the Backup Loader channel
    Open the Homebrew Channel and load the WAD manager.
    Press A
    Then A again
    Now select the BackupChannel_0.3.wad and press +
    Press A to confirm installation.
  • DiddyDave
    • 213
    This is one of the few good posts many thanks I'm sure that people looking to do the softmod will look back on this post for help.
    I use the softmod my self so I know where you are coming from when someone is going to do this for the first time.
    • johno1135
      • 28
      cheers m8
      just got zelda so here goes
      • dowlinr
        • 226
        Originally posted by johno1135
        cheers m8
        How did you get on?
        • DiddyDave
          • 213
          One thing I would say is that once you have applied the hack is to remove the wii from the net so this does not do an auto update if you leave it on without using it for a while. If the wii does it's update the hack will stop working.
          • Pittsey
            • 33
            Cheers Dowlinr.
            • dowlinr
              • 226
              Originally posted by Pittsey
              Cheers Dowlinr.
              haha, bring it round my house and I'll do it for you
              Btw, have you got a copy of Zelda? I had to borrow one to do mine.
              And more importantly have you bought Jake's Wii yet?
              • Pittsey
                • 33
                No, and No.
                I am waiting on some money from work. I will have to ask about for Zelda. Or go to Blockbuster.
                • middlewingnut
                  • 55
                  Thanks to all - as the tut here are so clear, I've put Zelda on teh christmas list and boxing day will need to send the kids out for a nice long walk.
                  • dowlinr
                    • 226
                    I'd try and borrow it if you can mate. You only need it for 10 mins, if you want to play the game after that then just download it
                    • dell_xps
                      • 2558
                      Got to be one of the worst games on the Wii, IMHO,
                      • drawflex
                        • 440
                        Downgrade to 3.2 and install starfall.. it stopps update check and you won't have to worry about this.
                        'He's not the messiah, he's a very naughty boy'.
                        • wmccull
                          • 67
                          So does this mean i can play online after its softmodded and patched , without any probs ?
                          • drawflex
                            • 440
                            yes mate... no probs
                            • jhardluck
                              • 5
                              Can anyone give instructions on how to downgrade my software to 3.2 so, I can install starfall as suggested above. Is this necessary and should I do this before setting up the Homebrew and Loder channels. Thanks in advance for any advice.
