4.1 UPGRADE BEFORE SOFTMOD???
  • H4MST3R
    • Apr 2009
    • 18
    Hi all......
    i need to softmod a pals 4.1e. Should i upgrade to 4.2e then apply the softmod, or just apply tthe softmod to the 4.1 ???
    Many thanks in advance
    H4MST3R
  • reddevil157
    • 1427
    Just do the 4.1 softmod, you'll get everything you need on 4.1, don't forget to install pre / priiloader at the end and enable block online and disc updates in the hacks menu.
    • H4MST3R
      • Apr 2009
      • 18
      Thanks for that......i'm on it
      • H4MST3R
        • Apr 2009
        • 18
        .............Actually no i'm not...can't find the files......
        I have all the files ready to go for a 4.2 softmod...... will it be ok if i upgrade the 4.1 to 4.2, or is this gonna cause me problems?????......think it will be easier for me this way, as i know what im doing already with a 4.2
        • hulk691
          • 13
          Actually 4.1 or 4.2 is still OK. Just make sure you hombrew channel is updated. Older version of the homebrew channel will be deleted. Current yersion of homebrew channel is 1.0.8
          • H4MST3R
            • Apr 2009
            • 18
            thanks for the reply hulk....unfortunatly, as you can see from my other post, i cannot get either of my sd cards to work with the 4.1 wii.......yet they both work fine with the 4.2 console!!! ???????................ just waiting to see if anyone has any ideas regarding this!!
            • hulk691
              • 13
              Only advice re - format. Format as FAT32 first. If cannot try FAT.
              Use an external program like Panasonic SDFormatter.
              • H4MST3R
                • Apr 2009
                • 18
                thanks again Hulk.....tried it but same result (
