using usb loader GX
  • browno
    • 176
    using usb loader GX
    ho
    I am usin usbloader GX but am getting disc slow or no usb found after it counts down.
    Is there another program i can try ....can any 1 recomend anything ....
  • ck-ok
    • 2592
    Originally posted by browno
    ho
    update gx loader in loader settings make sure you have cios222/223 or cios249r19 or 20. installed.
    try swapping usb ports and what sort of drive is it?
    • browno
      • 176
      hi mate its a samsung model:hd204ui...
      How do i check if i have cios corrctly installed?
      • ck-ok
        • 2592
        this drive is it in an enclosure?
        • browno
          • 176
          it is in a docking station
          • browno
            • 176
            i have the cios you suggested and have changed over the usb ports....losing will to live
            • ck-ok
              • 2592
              this might be your problem.
              to be uptodate with your cios install this Digital Kaos - Downloads - ciosx 20b installer
              can you use the drive without the docking station?
              • browno
                • 176
                cant use without docking station.... how do i use this file, god i sound thick ...
                My excuse i am a newbie
                • ck-ok
                  • 2592
                  put it in apps folder of sd card and install from homebrew channel
                  • browno
                    • 176
                    which ios do i choose?
                    • browno
                      • 176
                      done that mate and no change
                      • happy_highlander
                        • 3535
                        ho
                        Try starting gx and waiting until it asks for your slow usb device then switch on the power to the hdd. That's the only way I could get an internal drive in a caddy to work. If it works you should only have to do it that way when you first turn on the power to the wii when you return to the wii menu to change games it will load mount normally in gx.
                        • ck-ok
                          • 2592
                          to see if the drive is working with the wii try formatting one of the partitions to wbfs just for now put a iso on it with wbfs manager and connect it to the wii and start gx and see if it can see it
                          • browno
                            • 176
                            tried that no luck.... do you think a differnt loader masy work?
                            • ck-ok
                              • 2592
                              try uloader http://www.digital-kaos.co.uk/forums...taller-143444/ dont bother with the cios installer though.
                              i think your problem is down to the hdd being in a docking station,the wii do's not like hdds running this way,do you have a usb pen that you can format to wbfs and see if it can recognise it
