USB Loader GX problem
need more info
have you updated anything?
is the homebrew still working?
have you tried a different loader?sigpicComment
CK-OK I did have another question for ya. When hooking up a external HD have you heard of any issues with the drives that are 3.0 and 2.0 backwards compatible???? Since the Wii isn't 3.0 should i only be looking for a 2.0 drive?? Also would you FAT32 or WBFS your drive????
Thanks for everything.
Beefer1991Comment
Check the link I gave you in the other post and check known working hddCK-OK I did have another question for ya. When hooking up a external HD have you heard of any issues with the drives that are 3.0 and 2.0 backwards compatible???? Since the Wii isn't 3.0 should i only be looking for a 2.0 drive?? Also would you FAT32 or WBFS your drive????
Beefer1991Comment
CK-OK HELP
Remember me??? I was the guy with the Frezzing issues with my Wii and you told me to redo my wads to fix the issue. Well I did it and seemed fine. My question now is that when I upload a game it has seemed to go back to the Freezing Issues again. I tried reinstalling the wads again. But didn't fix it. I tried checking the nand for bad blocks and such and I was gonna upload my backup nand back on to see if it would fix the issue but its telling me that it can't find bootmii and that maybe the SD card maybe be corrupt???? Any ideas as to what I should do???
Thanks for your help like always.
Beefer1991Comment
what games are you trying to play? it could be your not using the correct cios for each game.Remember me??? I was the guy with the Frezzing issues with my Wii and you told me to redo my wads to fix the issue. Well I did it and seemed fine. My question now is that when I upload a game it has seemed to go back to the Freezing Issues again. I tried reinstalling the wads again. But didn't fix it. I tried checking the nand for bad blocks and such and I was gonna upload my backup nand back on to see if it would fix the issue but its telling me that it can't find bootmii and that maybe the SD card maybe be corrupt???? Any ideas as to what I should do???
Beefer1991
are you still using gx2.0? if so installing ios58 for usb2 support is needed http://wiibrew.org/wiki/IOS58_Installer then installing the latest hb channel http://bootmii.org/download/
as for bootmii folder you might have it on your sd card already but it may be renamed to bootmii old or something else, if it is on the card already rename it back to bootmii.
__________________Last edited by ck-ok; 5 March, 2011, 14:39.sigpicComment
CK-Ok I did the IOS58 and also ran the updated the USB Loader GX 2.0 and when you select any games and click the disc the screen goes blank and then nothing. When you first fire up USB Loader GX is shows loader settings 249 Rev 17 when loading. Not sure what I should do next. I'm running a 750 gig Seagate USB hard drive partisioned 600gig Fat32 and the rest is NTFS.
Any help is greatly appreciated.
Beefer1991Last edited by beefer1991; 6 March, 2011, 14:08.Comment
have you updated the homebrew channel from the link in my previous post?CK-Ok I did the IOS58 and also ran the updated the USB Loader GX 2.0 and when you select any games and click the disc the screen goes blank and then nothing. When you first fire up USB Loader GX is shows loader settings 249 Rev 17 when loading. Not sure what I should do next. I'm running a 750 gig Seagate USB hard drive partisioned 600gig Fat32 and the rest is NTFS.
Beefer1991
what games are you trying to play?sigpicComment
How do you upgrade homebrew??? where do those files go??? Also what version is Homebrew, looks like i have 1.0.8
Beefer1991Last edited by beefer1991; 6 March, 2011, 14:30.Comment
sysCheck v1.6.2 by Erik Spyder
Region: NTSC-U
The system menu v449 is running under IOS58 (rev 6175)
Hollywood v0x11
Console ID: 113086815
Boot2 v4
Found 112 titles
Found 48 IOS on this console
Found 3 IOS Stubs on this console
Did I do this right??? when i ran it, it looked like it was almost done and the screen when black and froze??? i had to hold the power until the green light shut off. So should i rerun it????Comment
