homebrew wii stoped as i did this ?
  • tripper
    • 42
    i just got the home brew on my wii my son went to the normal place to play the game it asked for an up date it know dont work so where or what do i have to do know to get it to work again the bloody thing just cost me $ 50.00 to get it put on i dont start from the home brew screen there is another one so what do you use the homebrew screen for is that for internet stuff i dont know much abought it please some one help
    tripper
  • ck-ok
    • 2592
    did you pay someone too put the homebrew channel on?
    the homebrew channel is for running apps on your wii.
    you should now be playing your backups with neogamma.
    if your homebrew channel is still working then follow this tut http://www.digital-kaos.co.uk/forums...-3-mod-157379/ from the section after installing homebrew making sure you install priiloader to stop it from asking to update
    • tripper
      • 42
      i think i might have to take it back to this ***** to get it done i cant work it out if you could email me the info in righting how to do it would help as i dont know two much i want to find out tho sick of paying $100 for these games only if you can do it i am not expecting it just let me know thankxs again tripper email add [email protected]
      tripper
      • ck-ok
        • 2592
        do you still have the homebrew channel?
        • tripper
          • 42
          yes dont know what to do tho
          tripper
          • tripper
            • 42
            the home brew chanel is still there & the neogamma when i start it goes black wont load game or what ever site it is where i start my games from i wanted to no will i need the game again to fix it when i try start it just goes black screen nothing happen remote turnes off and cant even go to woo home screen have to power off hey man tank heaps for all your help so far will have to tell more people abought this mad site
            Last edited by tripper; 31 January, 2011, 13:33. Reason: wrong spelling on some thing
            tripper
            • tripper
              • 42
              and i must be silly the home brew chanel is to use wireless with the internet hey can some one let me know
              tripper
              • ck-ok
                • 2592
                ok you already have the homebrew channel so download the mod pack from here http://www.digital-kaos.co.uk/forums...-3-mod-157379/ then follow this
                format sd card again and extract modpack from the folder you downloaded earlier to sd card
                run md5summer.exe and click verify sums and check theres no errors
                now you need to install your wads.
                Start HBC, press [HOME], Launch Bootmii
                Multi-Mod Manager Starts (via cboot2)
                Never Uninstall IOS, you will brick your wii
                Select "WAD Manager" - Press A
                Press (1) to "Install all Wads" - Press A
                19 wads should install without issue
                "Press any button to continue"
                Be sure all the wads install, very important
                If the wads fail to install, install 1 at a time
                Press B two times- main menu
                thats it nearly finished just need to install priiloader
                You should now be at the main menu of Multi-Mod Manager
                Select "App Manager" -press A
                Select priiloader -press A
                Read the warning- Press +/A to install -if needed Hold B press +/A to install with cIOS
                After priiloader installs, it may freeze during restart- this is ok
                Hold reset and boot wii while holding reset- priiloader will load
                Select "System Menu Hacks"- Press A
                Enable "Block Disk Updates", and "Block Online Updates", others if you like
                If MMM loads at boot, select Manage Priiloader, Edit Priiloader Hacks, enable needed hacks.
                If you don't know what the hack does- you don't need it.
                Your wii should now block Disk updates and online updates
                if you still keep booting to mmm try renaming bootmii to bootmii-old
                Note: Prilloader installer gives two errors-
                /loader.ini couldn't delete error -106
                /password.txt couldn't delete error -106
                this is not a problem just carry on
                thats it done
                • tripper
                  • 42
                  will i still need Lego Indiana Jones games to do this still just need to know that
                  tripper
                  • ck-ok
                    • 2592
                    no you already have the homebrew channel
                    • tripper
                      • 42
                      thats all cool but the home brew channel is working its where i start my burnt games from i cant work that part out i down loaded the stuff put to sd card still no go i think i need some thing else its the neogammer that wont start the games any ideas ould help heaps
                      tripper
                      • tripper
                        • 42
                        wii neogammer
                        i did an up date now it is not working can anyone put me on the right track to get it working again any ideas what to do
                        tripper
