help with ios58 - wiiflow forwarder/channell
  • jimja
    • Feb 2011
    • 88
    Hi all, new to forum..and softmod
    I have a softmod 4.2e
    i have wiiflow working through HBC 0.8,and usb drive, i also have installed priiloader, bootmii as boot2.
    the problem i have is im trying to install ios58 so i can install a wiiflow forwarder to create a channell on the main menu (so the kids cant mess it up!!)
    I have followed instructions installed ios38 and ios61 then reinstalled homebrew and it shows the ios58 when i do this but when i come to install the wad in wadmanagerv1.4 it show in my list (wiiflow - wbit.wad) itsays >>installing ticket...ERROR (ret = -2011)
    and no channel is present... ca anyone see what im doing wrong.. any help will be appreciated.
    ps. the ios58-61 were packed on my pc using the download program as whe i tried to download it from the homebrew browser it failed..
  • ck-ok
    • 2592
    why are you installing these ios's?
    try putting wiiflow forwarder in the wad folder start wad manager and install the wad using ios249
    • jimja
      • Feb 2011
      • 88
      thanks for reply
      really only to play game iso's i had bootmii to backup NAND
      priiloader for update prevent
      thanks will try that
      • ck-ok
        • 2592
        thanks for reply
        let us know if it works
        • jimja
          • Feb 2011
          • 88
          right.. i think im tryin to run before i can walk.. i originally installed USB loaderGX (it is still in the apps folder) but prefer the look of wiiflow.
          when u say install on IOS249.. the wadmanger does not give me a choice it just says install.. the wiiflow guide said i needed IOS58.. sorry if this sounds thick but i have read too many guides i think..
          PS should my sd card just have wiiflow and wadmanager (in the apps) and the forwarder in the Wad folder.
          thanks.
          • ck-ok
            • 2592
            thanks.
            you just need ios58 on your system for usb2 support download it from here IOS58 Installer - WiiBrew you will need to reinstall the homebrew channel after, the link is on the same page put hbc installer in apps folder and run from hbc
            you can have as many usb loaders as you want in your apps folder
            when you start wad manager select install from sd slot and when you come to installing part press right on the d-pad on wiimote to scroll through the ios's choose 249
            • jimja
              • Feb 2011
              • 88
              tried using wadmanager 1.4 to install but cannot move right or left to change iso .. all it says is install wad but no destination..
              dop-mi says that 249 has version 17 just noticed its dop-ios im trying and it dosent give me any options to install it...
              wait a min... its dopIOS im using..(what a dick)..just read that dop-mi .allows ios select...
              gona give it ago just now..
              • jimja
                • Feb 2011
                • 88
                no no erorrs some thing went ok.. gonna try looking for new wad manager as mine dosent seem to be good..
                • jimja
                  • Feb 2011
                  • 88
                  Thanks CK-OK.. f got it working now..
                  Installed the forwarder with wadmanager 1.7 and dop-mi for other bits not
                  thanks again for your help!!
