How to transfer data from one PC to another?
  • hotlife
    • Oct 2011
    • 50
    i recently purchased a HP HPE H8z Desktop Computer, it sports a 1.5TB Hard Drive and 10GB of RAM. A Massive step-up from my old HP Pavilion dv6-2157wm laptop with a 320GB and 8GB of RAM.
    So, here is my question. Is there a way that I can transfer some files over from my Dv6 Laptop onto my HDE Desktop? Anyway without an external Hard drive or anything like that? Nothing Fancy, just a folder or two, some photos, music Files, and some documents without damaging them in the process? I can easily reinstall my Anti-virus and a few games later, so I'm not too worried about them.
  • Grizz
    • 1598
    An ethernet crossover cable, or an ordinary one should do the job as well.
    • shagx
      • 50
      You could use a dvdr or USB stick then you would have a proper backup as well then
      • johnboy1974
        • 3418
        I done this recently using the bluetooth on both machines.
        • joshpcurto
          • Nov 2011
          I would use an external harddrive depending on how much information you have on the old computer and how big of space your external or flash drive is.
          • Jaffa
            • 1612
            If the old hdd in old pc is sata and obviously new pc is sata, then take the old sata hdd out and put it in the new pc, that way you can have all your photos etc on a seperate drive and an extra 320gb of space, if you wish to use the old pc and need the hdd, then just transfer the data and take hdd back out.
            • Reapers
              • 242
              i think it boils down to how huge these backups will be
              because you want tech to be able transfer as fast and
              not wait
              some are good for transferring small files but not big ones
              Bluetooth- good for small media transfers
              Bluetooth 2.0 -2.1mbps
              Bluetooth 3.0 -24 mbps
              Wireless - Your looking at Dual N so less hassle on channels
              and loads of speed
              if your going wired then
              Wired= 2 Gigabit ports plus cable unless you count router but ports come pretty
              standed on motherboards nowadays check to see you have them
              having just gigabit's connected allows you to have speeds to 1 Gbps
              the other solution to wireless transfer or using gigabit to transfer is external hard drive by using usb or sata
              usb 3 ports with a speed of 4.8Gbps
              sata 3 with speeds of 6Gbps
              if you use the option for usb or sata find a dock that uses usb 3 and sata 3
              make sure your motherboard supports them
              example
              [ame="http://www.amazon.com/Thermaltake-5-0Gbps-Docking-Station-ST0019U/dp/B003ZUXXVU/ref=pd_sxp_f_pt"]Amazon.com: Thermaltake 5G 5.0Gbps USB 3.0 SATA Hard Drive Docking Station with Hard Drive Pouch ST0019U: Electronics[/ame]
              • tmen
                • May 2012
                You can make use of Windows Easy Transfer in order to transfer your files from your old computer to your new one. As long as you are using an OS run by Windows then this should work fine and your OS should not be earlier than Windows XP. Windows Easy Transfer has several versions so you should look for the one that is compatible to your situation. For example if your old computer runs in Windows XP and your new computer is run by Windows Seven then this version of Windows Easy Transfer should work for you:
                Windows Easy Transfer for transferring from Windows XP (64 bit) to Windows 7 - Microsoft Download Center - Download Details
                I see a list of these versions in the site I've found in Google
                Transfer data from one PC to another
                I don't know what OS you are using so you can just look for the download link in that site. Thanks, hope this helps.
                • Morcegoblue
                  • May 2012
                  • 14
                  If u got a wirless internet modem u can uploud your data itens for another pc
                  HOPE IS LAST THING WE GOT
                  • youhin
                    • Jun 2012
                    cable
                    At first i suggest you have Windows Easy Transfer as a way to transfer your current files using an Ethernet cable. This free software grants you to retain all your data in quality locations however you will also decide custom folders and directories.
                    But you need to find the programs that is certainly available to your situation, a listing of the download links are provided here:
                    Transfer data from one PC to another - Darktips
                    hope this help
                    I also watch some of the vids
                    • seginus
                      • Jun 2012
                      Dropbox, you have 2 g in the free account.
