ram memory problem
  • nikoz
    • 116
    ram memory problem
    I have 1GB transcduser DDR2. When add 2 gb kingston also DDR2 memory computer won't star. Coputer work also when I put only one stick of memory (kingstone or transducer) with both can not start. Any sugestions?
  • cgscott
    • 3513
    What is the maximum the board can take? ALso what speeds are the ram?
    Patience is a virtue.
    • tigger001
      • 152
      what computer are you trying to upgrade the memory on , as some computers will only allow 2gb maximum.
      • Katallozi
        • Mar 2010
        • 36
        It could also be a faulty memory, how does the speaker sound when computer is turn on.
        • nikoz
          • 116
          My procesor is intel dual core 1.8 GHz
          Motherboard Name is MSI 945P Neo3 (MS-7236)
          • tigger001
            • 152
            From the info you have posted you should be useing ,
            800MHz DDR2-800, PC2-6200, 240p DIMM, 1.8v, CL=5
            The motherboard should have 4 memory slots so you can go up to 4gb as long as each slot has a 1gb memory stick in each.
            As far as I know you cannot mix and match different memory sticks with this motherboard.
            And you can only go to 4gb maximum. ( 4x1gb or 2x2gb )
