re convertxtodvd
  • chriss
    • 69
    #16
    that is what i have done and its ok now thanks
    • rds60h
      • 622
      #17
      No problem,glad I could help.
      • Donka
        • 184
        #18
        Convertxtodvd won't burn
        Originally posted by rds60h
        Why not convert letting it load to a file then close when converted, this file can then be burnt on nero. Thats what I usually do and I never have any problems.
        Hi done that but won't play on dvd player only play on pc. Would love to get to the bottom of why my covertxtodvd has stopped working, it used to work fine until now. After converting it just freezers whole pc when burning even when i try to burn already converted program, any help please.
        • Manic01
          • 5117
          #19
          Try deleting and reinstalling.
          • Donka
            • 184
            #20
            Thanks for your reply,tried installing upated version and same probs. It may have been same version but i installed again anyway to only find it was doing the same.
            • greengirl
              • Aug 2009
              • 18
              #21
              hi i had same problem with Convert X so im now trying image burn - have seen good reviews/recommendations on other sites. If I can burn a dvd with it, then it cant be that hard to use! Will let you know how it goes
              blimey, its only taken 5 minutes to do the whole film! I found it quite easy - just select the folder and click on the file i wanted - it did the rest. beats waiting a hour for convert x
              • cunny
                • 4915
                #22
                These are 2 differant programs. Convert x is a converting software that will convert .avi (mpeg 4) to dvd video (mpeg 2). Yes it does have its own burning facility but it uses the nero engine.
                Imgburn is a piece of software that burns dvds, compatable with most files, .iso .img. dvd files ect. I actually use both but mainly imgburn.
                If your having issues with convertx, things to try are new codec instalation, if its converting but not burning, instal nero. You could set it to create an img file somewhere on the pc and use imgburn to burn that.
                Another thing to try could be the update burners firmware.
                • barrowmanandrew
                  • 3427
                  #23
                  no way it's burned a dvd in 5 mins, does it work in dvd player? convert to dvd is simply the best software for burning and converting dvd's (in my opinion). there are lots of pirated versions of dvdx out there, some of them work, alot dont, just keep trying until u find a working version......
