ps3 problems help needed with ps3 jailbreak
  • raebie
    • Mar 2010
    My ps3 blu ray drive has died. I have seen that there is a ps3 jailbreak hack out for ps3 and i was just wondering if there is anyway you can use this jailbreak hack to load games without having to insert a disc into the system to simulate loading?
  • 54m33r
    • 22
    I am having the exact same problem i am not sure but you cann run games off your external hdd.
    • raebie
      • Mar 2010
      How do you run them from your external hdd? I have my games on my external hdd but they are not detected through my ps3 when i connect it until i transfer them over to the ps3 but then i cannot load them up without loading a disc in the drive which i cannot do as my drive is broken. If you can run the games straight from your external hdd can you tell me how to do it because i cannot find a way to do this?
      • MrFug
        • 880
        You can run games from your external HDD, but not if they have files over 4gb, as FAT32 doesn't support these filesizes.
        You can also run SOME games without a disc in the drive.
        Check PS Jailbreak Compatibility List - Home for info on which games run from ext HDD and which games run without a disc in the drive.
        • deffc0n
          • Aug 2009
          • 894
          Write CFW 3.55 no problem anything
