no disk drive
  • umesh10
    • Feb 2012
    • 21
    no disk drive
    Guys,as my earlier post I brought a ps3 off ebay but it has no disk drive inside so how can I find out which drive I will need to get for the ps3? it is a phat version
  • pspmixer
    • Jun 2009
    • 750
    you need the logic board then you can get any other drive
    • ray156
      • 669
      (why start another thread for same question)
      • umesh10
        • Feb 2012
        • 21
        There is no logic board inside so what shall I do now? it is a CECHG03 model
        • ray156
          • 669
          between the two threads,this one and that one...
          you should find an answer somewhere.
          • cunny
            • 4915
            If its anything like the 360 used to be,m your ~~~~ed. Simple answer would be contact seller see if he has the PCB from original drive. Then you could buy a replacement and swap the PCB.
            They will be locked to eah console's motherboard so they cant be 'interchangable' Bare in mind tho, once u bought replacement drive ect then prob be cheaper go buy a new console and with less messing about.
            Your only hope at this point would be some kind of jtag hack
