help pls ps3 makes my com disconnect from internet when when both on_
  • douch
    • 29
    some one help.....i have my com connected to a-link roadrunner 24ap router by ethernet wire and my ps3 is wireless when i turn on my ps3 to connect online it connects .then my computer loses it connection to the internet after about 5-10min then i have to reset the router to start new connection for the com internet?is a setting on firewall i am not doing or setting on the router? hope some1 out there knows
  • abhishekb
    • Jun 2009
    hi, i have a similar problem, where i turn my ps3 on and my laptop loses wireless connection. i then have to disable and enable the wireless connection on my laptop for it to work.
    my router is a linksys wrt54g.
    • freeride202
      • Jun 2009
      • 4
      You might try and see if your router has the latest firmware update.
      • 313ste
        • Aug 2009
        • 14
        you need a router if nt got one alredi check the setting make sure they allow internet cuming thru but u will need another ethernet cable cumin from the router to pc
        • jetsada
          • 21
          I've not had this problem with my PC and PS3 however I have had trouble when I was using my Wireless-N Dongle in my PC and my Dad had his Wireless media streamer on the network which was using Wireless-B to connect.
          what kind of wireless are you both using on your computer/laptop? It may be that that's the issue, probably not as I think the PS3 is Wireless-G which should be fine with B.
          What Channels are you using? Are there any other wireless networks around you? (that was more of a problem a few years back but depending on where you live it could affect it)
