error 80010514 can't read blu ray disks
  • kubik612
    • Dec 2012
    I have this error on my PS3 and have tried cleaning the blu ray lense and restoring the system files, but neither have worked. Anyone have any other fixes? Would replacing the blu ray unit work?
  • iman
    • 101
    Start by having the system in standby.
    Hold the power button down till the system will turn on and turn off.
    Press and hold the power button again, and hold it: it will beep as it turns on and then it will double beep. When you hear the double beep immediately take your finger off the power button
    You will be prompted to plug in your controller via USB and then hit the PS button.
    Now you'll see a series of options, this is VERY important, as a miss click will result in erasing your PS3 HDD.
    The option you want to click is RESTORE FILE SYSTEM.
    Finally, it is going to restart and bring up a screen reading Corrupted System Data. Your PS will now replace this data Then you choose continue and that should be it.
    good luck
    Give Instructions To A Wise man And He Will Be Yet Wiser.
    • kubik612
      • Dec 2012
      Thanks iman but I have already tried that a couple of times but it didn't work.
      • cactikid
        • 12017
        no idea but i had an error on my blu ray,i googled the error code and i needed a software update,did you try a google?
        • kubik612
          • Dec 2012
          Yes did lots of googles. In the end I swapped the blu ray and circuit board from another PS3 we have and it works now. So it looks like the laser is done for and I have ordered a replacement.
          Thanks for your replies
