3k3y ODDE
  • cunny
    • 4915
    3k3y ODDE
    3k3y is an optical disk drive emulator for the Playstation 3 video game console.
    It is installed between the genuine Bluray drive and the PS3 motherboard.
    Once 3k3y is successfully installed and configured it can be used to make backups of your original PS3 game disks to USB media, and play those backups from USB media without the need of the original game disk.
    Several games can be backed up to a single USB media, making it ideal as a 'jukebox' for hardcore gamers as well as for families with children too young to handle bluray discs with appropriate care.
    3k3y works with most PS3 models, however there are a few exceptions, most notably the new super slim model and all PS3s which comes with firmware 4.xx (after retrieving the drive key the PS3 can be upgraded to any firmware). We are working to add support for these PS3's but you are adviced to consult with your reseller if you are in doubt whether your PS3 is compatible with 3k3y or not.
    Features
    Right Here, Right Now!
    Play your PS3, PS2* and PSX games from any USB media!
    No custom firmware required for operation** - you can update to the latest official firmware for PSN access
    User friendly intuitive interface
    Hardware and software for high-speed game ripping to PC
    no soldering required
    Multi-language support
    Compatible with both Fat and Slim models
    Supports most file systems, including NTFS, EXT2/3/4, and Mac OS X Extended
    High speed USB2 interface
    Powerful embedded Linux system running from Micro SD card (included)
    Linux firmware fully updatable from USB media
    FPGA fully updatable from USB media via built-in, in-system JTAG programming
    Recovery mode - it is always possible to recover from a bad flash Update your PS3 as normal, no CFW or game patching required
    Pass-through mode. (Use your PS3 in "normal mode")
    Work In Progress
    Built-in game ripping
    * Requires compatible console
    ** Currently firmware 3.55 is required for exctracting the drive key. Once the key has been extracted the PS3 can be updated to any official or custom firmware. We are working on hardware methods for extracting keys from PS3's already on 4.x firmware.
    http://www.3k3y.com/
