I must change my hdd (not recognized anymore at boot time)
According to your recommandation on speed i found this one :
SAMSUNG - 2.5pouces 250Go 5400t 8Mo SATA HM250JI
cheap but will Is be recognized ?
(The original is a seagate 40gb)
Apologies for hijacking the thread somewhat but I wanna know if 1tb hdd compatible with the PS3 are out yet and if the PS3 reads hard drives that big. I'll need to read up on that.
if you refer to the internal SATA then the largest internal 2.5" SATA drive is 500 GB, but I guess in theory if such a 1TB drive existed, then I can not see an issue with it at all.
also the cost of such a drive would probably be the same as a PS 3
Well apparently they are releasing 1terabyte 2.5" SATA drives compatible with the PS3 either in early 2010 if not late 2009, so they are coming.....my question was whether or not they were out yet - as for price I can't see it costing more than double what the 500gb drives do as it's double the space after all. The only real question is will the PS3 read all that space or only 75% of it tops, given that all hard drives don't quite reach the stated capacity.
do any of you use an external HD? and if so was it easy to connect with ps3? and once you have a external does that automatically become your primary harddrive? or can i use both at once?
