PS3 overheating help
  • krazylegz
    • 2834
    My sons spare old PS3 ( fat 80gb ) that he keeps at my parents house. Recently it's sort if started to overheat. The fan comes on at full speed and sounds like a plane taking off.
    I was gunna clean it all down inside and try replacing the thermo compound, however I'm seeing conflicting things on this. Some are saying use a card to spread compound evenly then put a small blob in the middle, others are saying just a blob. Which one is correct?
    Also is there any other tips to make it quiet again?
    PS3= krazylegz120282
  • teerak2uk
    • Apr 2009
    • 6074
    You can do either but more than likely needs reballing
    Oh and by the way if my post has been at all helpfull
    please press the little THANKS tab
    • krazylegz
      • 2834
      What's reballing? Is it worthwhile doing it or just wait till it dies and get a new one for him?
      Sent from my iPhone using my fingers n thumbs
      • teerak2uk
        • Apr 2009
        • 6074
        All explained here and is good price since not so long ago people were charging ?50+ but that's prob down to the release of ps4 now
        Check out this item I found on eBay: http://pages.ebay.com/link/?nav=item...d=291039281023
        • krazylegz
          • 2834
          Cheers for the link mate
          Think it needs reballing, redone it using the credit card to smooth the paste out and it's still the same, okay until start playing a game then fans kick in full speed
          • teerak2uk
            • Apr 2009
            • 6074
            Yep reballing or I think ps slims are at ?99 now I heard I think with Argos
            • Frogger
              • Oct 2012
              • 422
              I drilled holes in mine (underneath the hard drive and the top cover above) and then bought one of these of http://www.amazon.co.uk/Xett-Horizon...keywords=3+fan amazon and its no longer over heating.
              Problem solved...........
              • teerak2uk
                • Apr 2009
                • 6074
                Unfortunately they are too late for that and the fat units are of bad design hence noisy fan as even new out of the box they would run hot
                • dunkler
                  • 146
                  Why reball if the GPU is still working? I mean all balls makes proper contact otherwise the console would throw YLOD. Any ball not making any contact will result in YLOD. His problem is about overheating and has nothing to do with BGA yet! I would recomand for him to take the IHS off and replace that compound too. krazylegz be careful with CPU to not damage. Cut the rubber with a razor blade. GPU is more easy since you can pop off the IHS with tiny screwdriver but be careful to not push hard or you'll damage the chip. Also if you console is old and you're trying to do this, BGA *MAY* be broken during this operation.
