if you have the light i can tell you how to fix it. all you have to do is take the playstation apart down to the motherboard use a heat gun and heat up the gpu and the cpu for about ten minutes.what happens is the solder breaks between the processors and the board.caused from over heating.after you heat them up to melt the solder back in place dont move the board until cooled down then put the playstation back together and turn on.
that will fix 95 % of the yellow lights of death
