ps3 bluray laser fix
  • dazza1878
    anyone know where i can view the correct assembly of the bluray casing ? i've replaced the laser, only it's really noisy after the rebuild and still won't read discs .. i even have to lift the door with a card for it to spit the disc back out !
  • dazza1878
    ok here's an update ....
    i've since managed to reassemble the drive correctly, after which i have the same fault - the ps3 doesn't read or attemt to read any discs at all ... it will light up blue , spin , then flash red .. i'm not sure what the last one did (the laser , not the failure to read) ? i'll retry it sometime soon .
    soon i'll be an expert with this fault as i have two more to look at and interchange and what have you .
