pad not working in pes??
  • krazylegz
    • 2834
    for some strange reason my pad isnt working in pes 2008 or 2009?
    it works up to the point where i select my team and ready to play when the team is on the field, the x, triangle, square or circle dont work so players wont even kick off, however they show up in the bottom corner when i'm pressing them they just dont transfer onto the players??
    PS3= krazylegz120282
  • Raven
    • 748
    That is weird, I'm assuming you've tried it in other games.....I can't see how if it isn't a pad or pad port problem how the game couldn't register it ?
    • krazylegz
      • 2834
      yeah it owrks in other games such as GTA4.....wander if the patch i've put on for pes has went5 tits up??
      • Raven
        • 748
        I honestly don't know m8, really I'm as stumped as you are because there's nothing to suggest pad failure and so it SHOULD be fine with Pro Evo....but didn't you say it did the same with with the other PES game too ?
        Basically if it's definitely working fully and properly with all other games besides Pro Evo, then it's more likely a problem with the PES games...though good luck pinpointing it because I've really no idea what it could possibly be....now that you've brought it to my attention I'll have a scout around and see what I can find out, but if you ever find out what caused the problem, be sure to let me know won't you ?
        • dazza78
          • 178
          try uninstalling your saved game data m8, from the patch you put in
          try it then
          like you say it might be the patch .
          i cant see no other reason why your controller should stop working , when it works on all your other games
          just try that and let us know m8??????
          if its that then use my patch as that dont mess anything up with your controller etc
          dazza
          hope you sort it
          PS3 ID= thebeast-666
          • krazylegz
            • 2834
            feel like a right plum now .
            turns out it was my pad, when i tried it on other games the only button i never tried was triangle, and its triangle which i use for short pass on pes, hence not being able to kick off........doh!!
            • Raven
              • 748
              Certainly!
              I think what's more disconcerting is the fact you use triangle for short pass - what do you use for shooting, L3 ?!
              • dazza78
                • 178
                Originally posted by Raven
                Certainly!
                lmao didnt know you could use triangle to kick off
                • krazylegz
                  • 2834
                  i've always used the same buttons for years
                  triangle = short pass
                  square = long pass
                  circle = through pass
                  x =shoot
                  R1 = special controls
                  L1 =run
                  R2 = stratergy
                  L2 = change player
                  thats probs how am still sh!te
                  • Raven
                    • 748
                    square = long pass
                    x =shoot
                    L1 =run
                    R2 = stratergy
                    L2 = change player
                    If there was ever a way to virtually feel like you looked at a reflection in a mirror you just smashed, believe me I've just had it! Talk about lop sided n weird .
